Question about Peg Perego Gaucho Superpower
Peg perego diablo 12v ride on car
I need to know the specs. on this toy speed,measurements etc.
5 Suggested Answers
  • 143 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 143 Answers
SOURCE: I just put together a Peg perego Polaris RZR ride
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
Posted on Jun 01, 2009
  • 143 Answers
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
They seem to know a lot about these toys
Posted on Jun 23, 2009
  • 143 Answers
SOURCE: Peg Perego Gaucho Rock'in Worked for a minute than Stopped.
it sounds like a fuse is cutting it off.
They always help me with my repair problems.
hope this helps
Posted on Jul 20, 2009
  • 670 Answers
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
12v wiring diagram for perego johndeere gator
Below is a the wiring diagram for the Peg Perego John Deere Gator HPX. I also included the parts diagram.
If the images are too small you can find them online (as well as replacement parts & manuals from a Peg Perego service center) here: http://peg-peregoparts.com/diagram.php?num=IGOD0055
see also: http://peg-peregoparts.com/vehicle.php?num=IGOD0055&display=overhaul
Wiring Diagram
c321785b-edfb-474f-aeb5-b95b778733bd.jpgParts Diagram
18872932-1308-4a2d-be44-39e68011f567.jpg b
Best of Luck!
May 10, 2012 | Peg Perego John Deere Gator HPX Ride on...
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
You can get compatible replacement batteries for your ride-on toy from here.
John Deere Ground Loader Peg Perego Ride On Toy Battery 12 12 AH F2... You can just change the battery and use the plastic casing and wires attached to your current battery. This will save you a nice sum of money. It is not hard to do. Check this video to see how to do it.
Oct 03, 2010 | Peg Perego 12 Volt Rechargeable Battery
Battery is charged but car is still not working,
Nov 30, 2009 | Peg Perego John Deere Gator HPX Ride on...
Wiring specs for peg perego polaris 700
Jun 20, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Between the perego battery charger and the 12v battery is a wire that mates them both, do you know where i can buy another?
in some cases you can contact perego and they will have the correct items you need. My sons didnt work and I took it to the closest perego shop and they fixed it for me for free. Hope you get the problem fixed.
Apr 16, 2009 | Peg Perego John Deere Gator HPX Ride on...
Replace parts on ride-on toys
Apr 04, 2009 | Peg Perego John Deere Gator HPX Ride on...
Wiring was redone to accomidate handicaped driver I need manual
I called and talked to the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They didn't have a wiring spec but the talked my through it over the phone.
Hope this helps
Mar 31, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Cant find the charger for my peg perego battery
I would use the specific peg perego charger. I had a neighbor who used a different one and he ruined his battery.
You can purchase them at this website I found http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
Hope this helps
Dec 02, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego Gaucho Superpower Logo
884 people viewed this question
Top Peg Perego Toys Experts
Tony
Lawrence Oravetz
Mike Carew
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
