Question about Black & Decker BDHF200 Compact Heater
Heater Caution Light On
What does it mean when the caution light is all that goes on. I power up the heater and then it turns on the power light but after I put it on large room setting the light switches to the caution light and just buzzes. I tried to take it apart to remove the dust but was unable to due to some odd shaped screws. What kind of srcrews are these they look like a flat screw driver could take them off but they have a little pinch in the middle that won't let you take them off with a flat srcrew driver. What kind of technician can I take it to if I can't fix it? Would it just be cheaper if I buy a new one?
  • Anonymous Nov 14, 2007
    Caution light comes on when the heater is turned on.
  • Clark with Big Toast Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution!
  • 944 Answers
Now you can purchase this type of screwdriver head in most hardware shops, especially as part of a large set of bits (look in the box and you will see them) - otherwise find an old screwdriver about the right size and cut a small groove in the middle with a file or a hacksaw, or a bench grinder if you have access to one. Hey presto. (ps I am not sure of the correct international term for these screwdrivers, but here they are known as split slots. ) sometimes this sort of screw head is sloped so that it can only be done up, not undone, although with a little downward force you can undo fairly easy screws - just check first to see if it is worth sacrificing a screwdriver. Hope this helps :) ps try http://www.dewaltservicenet.com/ServiceNet/new.asp for a free electronic copy of your Black & Decker User Manual. You will need to create a service net login. Please select "I'm a tool user." and follow the instructions. Once logged in, you will need to select "technical publications" from the left hand navigation. When it loads, use the quick document finder and enter your product model number. Hope you fix it - please ask again if you need more help
Posted on Mar 01, 2007
I need the lighted switch on front of Patton milkhouse space heater model puh680-u but can't track down web sight to order.
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
May 22, 2010 | Patton PUH680-U Utility Heater
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
When my space heater cycles the lights in the kitchen dim whats the problem
the wiring in your kitchen may not be large enough to carry the load of the heater and the other things plugged in. it also could be a weak breaker. word of caution. a lot of people are now homeless due to the inpropper use of space heaters.
Dec 31, 2009 | Sunbeam LowProfile Space Heater
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Oct 21, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
The Caution Light ?
Nov 30, 2007 | Patton PUH9000-U Heater
CAUTION LIGHT only -- no Fan or Heat
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Mar 31, 2007 | Black & Decker BDCH100 Ceramic Compact...
Black & Decker BDHF200 Compact Heater Logo
554 people viewed this question
Top Black & Decker Heating & Cooling Experts
Paul Carew
Dan Apthorp
Shimon David
Shimon David
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
