Question about Dryers
Wont run just humm - Dryers
  • meganj24 Nov 17, 2008
    my just hums too, and won't run/spin...
  • 370 Answers
The start windings in your motor went out. You have to replace the motor. You can check by having someone hold in the door switch and press the start button while you spin the drum. If it starts then thats your problem. If it doesnt start it is still your problem. Change the motor and it will fix it for sure!
Posted on Nov 18, 2008
Wont start unless i use starting fluid then wont stay running
with some one turning the key and some one at the fill tube where you put gas in. With your ear close to the fill tube the other person turn the key on you should hear a loud humm. If you dont hear the humm i would probally guess on it being the fuel pump in the tank. A another way to check to see is locate the fuel rail and on the fuel rail there is going to be a tire valve stem cap unscrew that turn the key on and see if there is pressure by pushing the center and see if there is pressure . Now there is gas in the line and if there is pressure it is going to come out pretty fast so be careful.So that is the two ways to check to see if you are getting fuel to the engine.
Dec 12, 2010 | 2001 Mercury Grand Marquis
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Fan runs but compressor just humms and wont kick on
Check electrical connections including the contactor. Also test the capacitor. If the capacitor fails, it will prevent the compressor from starting. Click HERE to see images of what the capacitor looks like.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
My car starts but wont turn over
u might not have gas or full line felter is closd and see if you full pump is working befor you start the car see iif u her a humm from the full tank have sam one stand by the full tank jest tern the key to jest befor start and see if you her that humm from the frul pump good day
Jul 10, 2009 | 1992 Ford Crown Victoria
Fan wont turn t humms
Might need a little more information, but here goes. If the fan won't turn at all, you need to oil it, if you can spin the fan and then it slowly beguns to run ful speed, replace the run capacitor.
Jun 24, 2009 | Bryant 462AJC021BA Air Conditioner
Dryer wont run
sound more like a motor problem,, does it sometimes humm while trying to start ,,that first sign ,, repl motor
Dec 29, 2008 | Dryers
Car ran out of gas, put in a few gallons. enough to make the needle read 1/4 tank. car still wouldn't start. changed filter but the car still won't start
Hi, you should run a fuel presure test ,fuel pumps can get bad when they run dry afther runing out off gas ,Good Luck..
Aug 24, 2008 | 1994 Pontiac Grand Am
Dryers Logo
Top Dryers Experts
