Question about Toshiba Satellite A205-S4607 Notebook PC
Did you find a solution?
The exact same thing happened to my toshiba 205?
I have tried everything. The computer is just out of warranty.
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
The battery charges for 5 mins then stops any ideas ?
Welcome to Fixya.
If this same thing happens even when you charge the computer while it's turned off, then we might be looking into 2 major faults:
  • Battery
  • Motherboard (Contact point)
It would certainly be helpful if you can borrow a spare battery that will work on this toshiba laptop - if the same thing happens again, then it's the motherboard that needs to be replaced. Best to see if your computer is still within the warranty and check for replacement/repair options through the website below :
Support Toshiba
Thanks for using Fixya.
May 12, 2011 | Toshiba Satellite A60-S1591ST Notebook
I need driver to install in my computer to connect estudio205 with my computer as a printer.
Toshiba e-studio 205 drivers are available Toshiba Official Support
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-Studio 205
Select the drivers and download for your Operating System
You may also
refer to the product manual
Hope it helps! Good Luck!
CreativeTECHNOLOGIES
Apr 27, 2011 | Toshiba e-STUDIO205 Laser Printer
Toshiba NB 205 has "antimalware doctor" virus. Internet still works but about every 5 minutes the antimalware doctor pops up and interferes with everything I'm doing; and I am not able to access the...
Download Malwarebytes ( free version)
Install, boot into safe mode with network (F8 on boot up).
Run a full scan with malwarebytes.
This should get rid of that rubbish.
Please write back if you still have problems after that
Aug 30, 2010 | Toshiba Computers & Internet
Need a keyboard removal guide for Toshiba netbook nb-205-n230
If you need to ask "how", I recommend that you STOP, and take the computer to a qualified technician, who can safely and correctly repair your computer.
May 30, 2010 | Toshiba A75-S125 Satellite Notebook
My sound aint working on my laptop and it say`s there is no audio device but it was working last week. what should i do?
first of all, did you shut down the laptop compltely since that happened? sometimes there's a lot of stupid things happening with computers-suddenly drivers stop working etc. Try restart the computer if you haven't done so before.
if that doesn't help, install the drivers from Toshiba site. I can help you find the drivers if you can tell me which exact model you have of the laptop, and if you know the exact model of the sound card it would really help
Oct 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Scanner E Studio 205
U can download the latest viewer at below:
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Everything is inside the application, just follow the instruction.
May 15, 2008 | Toshiba e-Studio 205 Copier
Phillips 170b monitor not working
Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
Dec 31, 2007 | Computers & Internet
Computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite A205-S4607 Notebook PC Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
