Question about Husqvarna Chain Saw 20" Bar
After i use chainsaw the chain loosend
I have a manuel but doesn't say how to fix it i have tried but got nowhere
can you help me.
thankyou
tom
  • 16 Answers
First you loosen 2 bar nuts , then tighten adjuster screw ,this is on cover behind bar nuts or between bar nuts or inside bar on crankcase depending on what model you have ,its also helpfull to lift nose of bar while you tighten adjuster,dont over tighten chain ,then tighten bar nuts
Posted on Nov 17, 2008
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Had chainsaw serviced 50 hours running ago, but doesn't idle now. How do I adjust idle .thankyou
as chain saws operate in bad conditions , check the air filter for blockage
as there are many carby's on the market with screw adjustments or no adjustments , exactly what make and model would be a big help
Feb 18, 2016 | Garden
If my chainsaw starts but the chain doesn't
Its more than likley the chain brake has acttivated, grab the hand guard and pull it firmly fully back to the top handle, you should here a click as it loads, now try again
May 26, 2012 | Poulan Garden
I teally need a manuel for this chainsaw Homelite Textron UT104033. the sparkplug has alot of oil in it? and im, not sure how much tension is supposed to be in chain? obviously i cant seam to get it to...
Here is a helpful link for the owners manual and maintenance guides. The chain should be tight, but still have some movement when you lift the chain from the guide, however the bottom links should not come out of the guide.
http://www.homelite.com/catalog/chainsaws/UT43100
Aug 29, 2011 | Garden
What oil does a ryobi cs216 electric chainsaw use ?
if you are talking about the bar chain oil (?) --- then all you need is just that ' bar/chain oil ' ,, you can get it from any hardware store that sells chainsaws.
now out here in the middle of nowhere Alaska where I am,, we just use used motor oil from our generators as a bar chain lube and it works just fine, ( not my ideal thing to use , but that is what the boss says to use and after 3 years here and using it -- I have not had any issues with our 4 saws that get over 3000 hours of use every year ).
I say -- use only good,clean and new bar chain oil.
c...
Jan 18, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Require user's manual for an "efco" chain sharpener.
I have a user'manual for your efco chain sharpener. Send your mail adress.
Apr 05, 2009 | Garden
Sears 18" chainsaw i just finished cutting some wood and went back to cut some more the chain does not move I took the cover off and tried turning the sprocket thing it doesnt move this saw is only a few...
Assuming you can pull the starter cord and the engine turns freely (e.g. engine not frozen due to improper fuel mixture), check for debris near the clutch wheel.  Also, loosen the bar tension screw to see if the chain and clutch can move.
If you pull the starter cord and the chain moves, your clutch may either be jammed in the engaged position or may have gone out.
Make sure that you don't have the chain tension too tight and that you always have plenty of bar oil.
Jan 24, 2009 | Garden
Th echain isloose
please excuse my english.There are two locknuts on the cover of the chain sproket(release them a little)Now you have to find the screw to adjust chain tightening.It is in front or on the right side of the chain cover.For tightening move the screw clockwise andthen tighten the locknuts.
regards Mihai71
Nov 17, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
117 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
