Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Was told to replace carburator and gas tank on ryobi string trimmer, which no doubt it needs. where can U buy these?
  • 659 Answers
Well if anyone is going to have that parts then its gonna be Ryobi the best solution I have to this is to contact them directly and even order the parts from their website
https://www.gardnerinc.com/recons/splash.php
The above link is to the ryobi outdoor parts replacement store.
Posted on Nov 18, 2008
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Jul 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi bc30 gas trimmer wont run full speed will run at half choke but not full speed, when moved to run it dies.
I have the same issues. I think the solution is to toss it and buy a real one from an actual lawn care dealer that sells quality brands. Yes, they will cost about $200 and up, but it's worth it to have something alot more reliable, and can be worked on when needed. I know I have wasted more than that extra $100 in time/effort with this thing, and I still plan to buy a new one. So now, that quality trimmer will cost more because of the money I wasted on the Ryobi in the 1st place.
Jun 28, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
250 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
