Question about Samsung SC-D103 Mini DV Digital Camcorder
Blured when trying to record, very blured.
Plays previously filmed tapes back fine,. but not to record something new. The sound is there but unable to make out what was filmed
    Scholar:
  • 107 Answers
Look the responded I posted earlier
Cheers
Posted on Dec 05, 2008
Unable to switch from "Norm" audio track on old tapes
Hello, this problem is because of the nature of previously recorded signal. The recording made in an older way (mono) has a separate head and the solution for your problem can be to clean the head. This head has two functions, for control pulses and audio signal. If you need more info please advice. Arpi
Jun 03, 2007 | JVC HR-DVS3 Mini DV/S-VHS VCR
Tip
I've been unable to play several bought VHS tapes of films, though oddly,...
Vcr's commonly get dirty heads that cause a blue or snowy screen and no sound in some cases. In my experience the rental tapes were common point of trouble especially when you consider the amount of machines that were deployed in use back in those days. Today people run into less issues because they have there own collection and put them to good use. In order to deal with some people's problems there are three approaches to cleaning heads, the first option is to use a wet tape with the provided fluid usually two or three drops will do and run it for ten to twenty seconds. The second approach is use a dry tape with same amount of time as outlined above. The third approach is get a blank store bought tape "T120 2hours" set the vcr to sp and run the tape from beginning to end, this is a good way if you want do more of a deep clean to remove difficult dirty particles that refuse give way. I find the dry tape will give less problems when cleaning and less chance of shredding and easier for people who don't like taking vcr's apart.
on Jun 02, 2011 | Televison & Video
Too blured to record
You have a blue filter inside the lens assembly was decolored by heat and moisture it require a qualifier Tech from Samsung to replace that filter because it must dismantle the lens, in AUSTRALIA it would cost between $80 to $110 to replace it
I hope that give you some ideas
Nov 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
SOUND
sounds like a bad tape,have you tried recording on the other cams tape !
Apr 12, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Nov 29, 2007 | Mitsubishi HS-U560 VHS VCR
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Recording
This sounds like the CCD sensor is faulty ( this is the device that generates picture in both v-cams and normal digital cameras and sits behind the lens ). Playback is fine but no image ( or very 'noisy' image ) in capture mode. Easy to repair but one has to put a new CCD block in.
Sep 03, 2007 | Cameras
Samsung SC-D103 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
