Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
Maching was working fine. All of a sudden in mid spin cycle the electric goes out only in that room. After some investigation, found out it was washer causing GFI to trip. I thought maybe it was that outlet, but it tripped the GFI on all outlets in the room.
  • 291 Answers
Check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Posted on Nov 25, 2008
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
Gfi outlet trips right before the final spin cycle. This is on a top load kenmore 80 series washer. I replaced the timer but the problem still exists. The timer seems to be in a pause mode. In other words,...
Motor driven appliances can trip GFI outlets when there is no problem at all with the appliance. When a large motor first starts, it draws more current for a short time and some GFI outlets will trip (others may not).
Are GFI outlets required by code in your state/county for washing machines? If not, replace the GFI with a standard outlet. If so, replace GFI with a higher quality GFI outlet.
Nov 30, 2012 | Washing Machines
Why does he GE profile top load washer trip my GFI circut half way thru it's scan cycle
Earth leak either due to water in something or a ground fault in the motor is my guess. It may even be a motor windings fault that is building up resistance as it warms up. You need a service engineer with a good test meter,
Nov 18, 2017 | General Electric Profile WPGT9150 Washer
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Plese help
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Jan 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
229 people viewed this question
Sal De
 Brian Main
Brian Main
