Question about Aiwa CDC-X227 CD Player
AIWA CDC-x227 CDPlayer
Looking at the back of the unit -top side up I need to know the wireing hookup to voltages,ground,speakers etc. I lost my 12 pin connector when I moved (after taking it out of my old car which I rolled) and cannot rehook it up because the new connector I found has different colored wires. I would really appreciate some info or knowledge of a source to acquire this info. I will be anxiously waiting-Thankyou Very Much Sincerely Vince Rinchiuso
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Posted on Feb 02, 2007
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Aiwa CDC-X227 CD Player Wiring Manual. I'm just trying to find a FREE diagram of the wiring system of this stereo system...have the whole internet...and every page i go to-it wants to CHARGE me JUST to...
Do you have the speakers hooked up already and you just need to figure out the power,yellow and what about black ground?Let me know.I am looking around now.What car make/model are you putting it into?Also,where did you purchase the stereo?Online,store,etc.?
Aug 07, 2010 | Car Audio & Video
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
I dont know how to rewire the clip that goes into the back of my cd player...which are ground and acc, and direct power?
do you have harness going to your system if so you can match the wire colors together if not you will have to hardwire but keep in mind you will need a 12v tester with a light on it to check your ground lead your acc or ignition and then your direct or constant 12v you will have to check these three wires with a volt meter if you dont have a harness for your vehicle
Oct 30, 2009 | Aiwa CDC-X227 CD Player
I need a mauual for car stereo radio cdc-x227
Are you asking for Instruction Manual or Service Manual, please mention it.
Nov 28, 2008 | Aiwa CDC-X227 CD Player
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Nov 08, 2007 | Aiwa CDC-X204 CD Player
Aiwa CDC-X227 - No power to unit
Keep in mind that there are always two fuses in any vehicle that provide power to the radio. One fuse is for switched power, one for constant power. Both fuses need to be good before the radio will work. Often one of the fuses, especially the constant power fuse, is shared with other electrical circuits and may not be labeled as a radio fuse. Check all the fuses in the vehicle, including any fuse box under the hood. See if any other electrical systems in the car aren't working, especially the dome light, cigarette lighter, door chime buzzer, or clock.
Jul 28, 2007 | Aiwa CDC-X227 CD Player
Aiwa CDC-X227 CD Player Logo
276 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
