Question about Insignia IS-DVD1001 DVD Recorder/VCR
Insignia DVD Player
The player disc door will not open, nor will the VCR eject button work. The word "safe" appears whenever we try to open the DVD disc door, or eject the VCR tape.
  • 3 more comments
  • Anonymous Mar 16, 2014
    If I had another DVD Player that would work in the machine, I do have the technical ability to swap out the DVD myself.
  • Anonymous Mar 19, 2014
    Bought new funai DVD player watched DVD once second time I wanted to view DVD it won't play tried everything on remote all I get is a picture of two discs
  • Anonymous Mar 23, 2014
    I think my dvd player has gone bad. When I put dvd in, it just says, disc error or no disc. Is there a replacement dvd player available?
  • Anonymous Mar 24, 2014
    yesterday I put a dvd in my insignia tv/dvd combo and it worked. Today the same disc goes in and then is ejected. The same thing is happening to other dvds.
  • Anonymous Mar 29, 2014
    My DVD player not open eject it display no option. Please choose the correct procedure
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
I have this problem also, but am still looking for a permanent solution. It appears that this is a safe mode to prevent children from messing with the unit. I don't know how I activated it or how to deactivate this mode. I have found that all functions, including DVD and VHS Tape eject work normally from the remote. Use of the remote will give you complete control until the safe mode can be deactivated.
Posted on Dec 10, 2006
  • Alan Kalan Dec 10, 2006
    I just spoke to Insignia. They advised to unplug the unit for one minute, then plug in. If this does not clear the problem, the unit will have to be returned to the store for replacement. (It cured my Safe mode problem.)
It also may be the CD belt (inside, on the motor shaft) is broken.
Posted on Mar 22, 2007
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
DVD door won't open
It's likely the drive belt that controls the sledge the disc goes on has perished or fallen off. It should just need replacing.
Jan 07, 2018 | Samsung DVD-V1000 DVD Player/VCR
VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Apr 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd player
you must eject the tape in order for the disc player to work
Mar 30, 2008 | Sanyo DVW-7200 DVD/VCR
Insignia dvd player wont play some discs
How to unlock a dvd player Insignia NS-H2002-U for region free
Insignia NS-H2002-U
With disk In the player (must be allowed region on you dvd)
Press stop in the remote dvd control 2 times to have a dvd screen in your tv
Press 16719 in your remote no matter what appears in the screen, at the end the region menu will appear
Using down arrow go to region that you want, “0” is for region free.
Press ok and enjoy it.
If do not work, power of your dvd, turn on again, incert allowed dvd movie in your insignia dvd player, when start reading disk, press stop and the press setup in your remote control, set uo dvd screen appears, then press 16719 in your remote, region menu will appear and use down arrow to select your region code, zero is for all regions.
Enjoy it
Feb 17, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Safe
There should be a button on your remote labeled "safe." Press that, and it will turn the safe mode off. It's on the second row from the bottom on my remote.
Jul 15, 2007 | Sanyo DVW-6100 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
944 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
