Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi VS-50707 shuts down sporadically
My 2000 Mitsubishi VS-50707 will turn itself off sporadically. Sometimes only once over a two week period, other times it will turn itself off 6-10 times in a day. It always takes at least 20-30 minutes to reset and turn back on. If you don't wait, it will just click and turn right back off. Is it time for a new tube or can this be fixed for a minimum charge. I would like to get more than seven years out of a $2200 T.V. Need help please!!!!! won t turn on
  • 4,806 Answers
I agree with ginko!!! if you have a look on the forums this seems to be a common fault with these tv's check all the power relays and capacitors and clean the dust from it, when the TV is on and if the picture is crisp then i doubt its the lamps
good luck and kind regards
Posted on Nov 17, 2008
  • Mitsubishi Master
  • 19,396 Answers
I dont think the problem is the tube.
It is probably a faulty power adapter, or a lamp problem.
  • Ginko
    Ginko Nov 17, 2008
    If it turns off always after a while, let say after two or three hours, each time you turn it on, then it is overheating.
    If instad, as you say, it is totally random and happens once every couple of days, then it is probably a faulty power board, or a different component that is starting to fail.
    Only sporadically similar problem are caused by expensive parts like the ligh
    engine, and even a digital board it is not too expensive to replace.
    Depending on what part must be replaced , the repair job should range between $200 and $300.
3 Suggested Answers
  • 1153 Answers
SOURCE: Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Posted on Mar 10, 2008
what if the pic doesnt stay on long enough to run the test? Mine doesn't stay on more then 15 seconds before it powers off. This happens everytime now.
HELP and THANKS
Posted on Apr 07, 2008
It won't turn on
on off sensor/switch bad, pretty soon it probably won't come on at all
Feb 26, 2010 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi big screen TV
Sounds like something in the deflection or audio circuits. Wish I could help more. I will post a link where you can get the service manual.
http://servicemanuals.vstore.ca/
Feb 28, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707
Check the CRT socket of the tube that is arching. Could be a solder connection or shorted CRT. If you need further assistance let me know.
Feb 03, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
VS 50707 turns on, then off immediately
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
50707 does not turn on, goes off immediately code 24, relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 27, 2007 | Mitsubishi VS-50707 50" Rear Projection...
TV turns off right away relay clicks
Aug 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
