Question about Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo
AKAI 50"LCD T.V.
Having a problem with full screen picture in normal mode HDTV stations some come full screen some don't. Is it a satelite problem or T.V.????Help
    Champion:
  • 217 Answers
You need to check the resolution settings on your cable box
Posted on May 27, 2007
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Can't get full picture when not on HD station
Check its screen resolution settings. 4:3 and 16:9. If it is set to 16:9, bottom and top part of the screen will cut off. The same effect will be there if it is set to 'wide' format.
Jul 03, 2012 | LG 42CS560 42 Class LCD HDTV
How do i get a picture thru component 2 so i can get 1080i quality. i only get a picture thru component 1.
You would need to unplug the input cables in the TV and move them to component 2 on the back. Assuming your input is at 1080i in the first place (ie, the cable box or digital satelite signal is coming in at the proper resolution). One way to check is to connect an external DVD player to the component 1 input and see if the picture is higher quality than the signal from the Cable/Satelite. Not sure changing to component 2 is going to make a difference. Good luck and let me know what happens!
Nov 04, 2010 | Akai PDP5090 50 in. HDTV Plasma Television
When on wide mode there the full screen is not
This is very normal not all channels are HD some programs are taped like that will not fill your screen like dvd movies are.
Nov 18, 2009 | Insignia 42" LCD Flat-Panel HDTV
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
Picture stretched on right and left edges.
I have a 32 inch Akai that does this from the built in DVD player mode I would try to get into the advanced video options on the menu I don't have a remote so I can only advise that far
hope that helped some.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture cuts off at bottom of screen
Do your basic trouble shooting first, disconnecting satelite or cable box, etc. to eliminate bad attached components or cables. How old is the bulb for this model. They are only good for three years of so. $300.00 part. If the main Wega engine is out, look out, expensive part. Have a qualified tech look at your unit. It will pay for itself as the picture looked even better than new after repairs.
Jul 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo Logo
97 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
