Question about Directed 3124 Car Subwoofer
Hi-- i have a question!
My name is Geo, i have a civic with 2 12 inch subs, for some reason the subs work when I turn on my car then about a minute later they turn off. I checked the connections on the amps and everything is tied in. what could it be?
    Problem Solver:
  • 8 Answers
It could be a few problems either ur ground is in a bad spot or like mine i took it off and there was rust around it. Or your subs could possible be blown or maybe ur amp is pulling way to much juice try turning the gain down and if that doesnt work u have a short somewhere
Posted on Jul 25, 2010
Is a 1994 civic subframe compatible with a 1997 civic
Eg and dc2s are interchangeable but ek. Different
Feb 19, 2015 | 1997 Honda Civic
The car drives when you come 2 a stop and take off again it rears up and wont go until u turn it off and it goes again
are you saying , it stalls (RPM on dash goes to 0)
or RPMs are below 800(hot and is wrong) ?
or that all the above is ok, but I have lost engine power?
if A/T transmission slip, (RPM goes way to high and MPG dont track RPM correctly)
is car an A/T
when asking for help , stated engine size and transmission options.
we dont know. and Civic sub model name is good to... we are blind here.
Jan 01, 2014 | 2002 Honda Civic
Starting problem on my 1996 honda civic
Look under the dash all the way beside the drivers door. bolted to the wall is a relay about 2 inches by 3.5 inches wide and about 1.5 inches thick. Its called a MAIN relay. At o'reilly auto parts the number is R3046 by BWD. Its a simple plug in connection. I'd try that first. And trust me, ask for it by the part number, not the application. I worked there at one time.
Jan 15, 2013 | 1996 Honda Civic
Check Engine light 1998 Honda Civic 4 door automatic trans
You need it checked by your local auto electrician or friend who has a scanner.The reason check engine came on is a faulty sensor/component.
Jul 21, 2010 | 1998 Honda Civic
1300a, no sound, protect light
if u have the amp bridged un bridge it. chack an see wat the ohms are on the subs an make sure the amp is stable to carry the ohm load..if u have 4ohm subs one sub per channel then u shud be fine that wud make the amp see 4ohms but if u have dual voice coil subs it cud be the configuration of the subs..here's a link on how to wire subs hope this help..http://mobile.jlaudio.com/support_pages.php?page_id=145
Jan 12, 2010 | Car Audio & Video
97 civic coupe AUTOMATIC TRANSMISSION WORKS FOR A MINUTE
make sure you check trany fluid with car on!!
Mar 25, 2009 | 1997 Honda Civic
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Sub not working any more
mine does the same DONT BUY SONY XPLOYED THEY EXPLOYED!!!!!!!!!!!!!!!!!
Jun 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub box inner space measurements in inches
First off I have some questions to ask you? what size are your subs and what is the max power on them and the brand name?
Dec 18, 2007 | Car Audio & Video
Directed 3124 Car Subwoofer Logo
19 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
