The my book usb drive i just got worked for 2 days, since i shut down my computer when i plug it in to the usb port nothing happens, but when i unplug the drive it causes my computer to reboot, something about i/o device error...it is a 1T my book drive...
  • 4,806 Answers
Try the USB drive in another PC or device to make sure that its not the USB thats faulty, if it is, have the USB replaced
regards
Posted on Nov 17, 2008
When I plug my camera into the USB port nothing comes up on the screen for me to import photos like the computer does not recognise my camera is plugged in. This just started happening today.
Try going and shutting down and unplug the computer. Push the start button until if flashes. The go ahead and plug computer back in the wall socket then restart do not connect the camera yet. Once your logged on and settled in. Then plug the camera back in to the USB port. It should pick up the driver and open options for what to do with the files. Also make sure you are powered on with the camera when you plug it in.
If it still does not pickup the camera go ahead and install the driver disc again for your camera or the software disk. Then try it again. Also go to my computer and left click to see if it is showing up in the devices. I hope this assisted you thanks for using FixYa for all your computer questions. John
Feb 08, 2011 | Computers & Internet
Could the Freecom Tough Drive 500GB turn computer off? It is happening with my computer pretty often. I did experiment with another computer. Another computer was shut down as well. I have already come to...
Wouldn't surprise me, I just fixed a Dell xps that wouldn't boot from cd/rom or hdd. Whenusing a different hdd it booted fine. After 3 days & finally testing it on another machine via usb,so I could scan it, there were 49 viruses that apparently can shut down a hdd,cd/rom, even an entire pc. Could also be a problem with the power board for the hdd if it plugs in usb. I have an issue currently where if I plug anything into my card reader it bsod's on me.
May 12, 2010 | Computers & Internet
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
USB Troubles
How To Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
Sep 28, 2009 | Dell Dimension E310 PC Desktop
My 2 usb ports on my monitor not working
In order for the two USB ports on the monitor to work, the monitor itself has to be connected to your computer via another USB cable with connectors that look like this:
The flat connector goes into an available USB port on your computer, the square one plugs into your monitor. Check if your cable is connected properly or exchange it with another one.
To eliminate that there is something wrong with your "not recognized device", plug this device into another USB port of your computer. The reason to preferably remove the device safely in Windows is that you can loose data if you just unplug it. If it is an external harddrive, it can get damaged, because you interrupt the power and the read/write head can get "stuck". So check this device on another computer or USB port.
If you have any other questions or something is not clear to you, just come back here and leave a comment and I'm happy to help.
Apr 13, 2009 | Computers & Internet
My USB ports don't work
good day,,
your usb port has the problem.. try to follow this steps:
1. Try to check if the usb bus is installed, to do this right click on my computer
2. Click manage
3. Click Device manager
4. On the right side click on the plus sign of the universal serial bus controller
5. Check if all the item is in correct
if you are done and then the problem is still the same,try this one
1. Re-install your motherboard chipset
2. Ensure to install and try to look if the computer install the usb serial bus controller
tanx..
Jan 31, 2009 | Computers & Internet
My hard drive is not being recognized but its still getting power too it but its not showing up on the computer any where so i think there is something wrong with the usb port on the hard drive
Shut down computer, plug in USB hard drive, start computer, open "My Computer" and see if drive shows? If so, you may have to format it before using it.
Jul 15, 2008 | Computers & Internet
I have a "My Book", Essential Edition, External drive, which a friend set up for me with a lot of information on it. When I plug in the USB and the addaptor (after having my MAC Book booted up),...
gud day...does ur mac book support any plug and play device? if it is then try to plug it to ur another usb port if it doesnt work...there sumthing wrong with your mac book.,it means that your mac book doesnt recognize the hardware to attach on to it...or ur mac software doesnt support the external hard drive...mac book operating system doesnt work with your essential edition external drive
Jan 14, 2008 | Computers & Internet
Usb
go into your device manager and see if you see any yellow question marks by any usb devices on your pc if there is make sure your online and try an update see if that works first. Also how are you shutting down? are you using the remove hardware Icon on the bottom right? You could also try the Add and Remove hardware in your control panel, Let me know if that works if not write back here.
Dec 23, 2007 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
