Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Comp to dvi problem
I brought a dvi cable to install my laptop to my rca monotor. for some reason I'm not getting any picture when I tune my t.v to the dvi channel. and everything is hooked up. please help
  • sublimeguy83 Jan 10, 2009
    i have a dvi-d dual cable running to a dvi-vga adapter and i get sound from the audio splitters but i dont get video either .. i think it might be my laptop graphic card isnt strong enough for this .... but i have s-video that works so im guessing ill have to sacrifice the video quality until there is a fix??? anyone out there have any solutions?
Try going into your control panel in your computer and if you have nvidia then open the settings and it should set itself to it. or try to start your laptop up with the tv on. there should also be some hotkeys you can use to change the output of your tv.
Posted on Jul 05, 2010
  • 3 Answers
The RCA will not respond to a DVI-I signal. So make sure your laptop is actually DVI-D, and not DVI-I. The easiest way to check is look at the plug on the TV verses the plug on the laptop. If your Laptop has a DVI slot that appears to have more prongs it's a DVI-I, and will not work.
Posted on Nov 25, 2008
    Problem Solver:
  • 61 Answers
There are some settiings on your laptop you need to set specific for tv monitors different dvi format is used
Posted on Nov 22, 2008
I have a Rca scenium tv ...trying to connect to my hd reciver and can not get a picture ...tried hdmi cord ..adapter ..dvi cord ..and nothing at all
Easy to understand, hooking up RCA, HDMI, and othe ...
? 5:54
https://www.youtube.com/watch?v=m4jgK7Ws_6U
Jul 10, 2012 - Uploaded by kevintalkstech
A very easy to understand tutorial about what RCA, HDMI, coaxial and ... +kevintalkstech I am trying to learn ...
How To Connect: Tv + Component With Dvi Or Hdmi - Rca ...
www.manualslib.com > ... > User manual
RCA SCENIUM HDTV With DLP Technology High-Definition Television ... To connectyour TV to a component with a DVI jack, use an HDMI cable and an ... Note: You canset up the TV to automatically tune to the correct Video Input Channel. .... call me at 318-578-5198 I need help as soon as possible trying to get my tv to ...
Support - RCA Television
Dec 27, 2015 | RCA Televison & Video
WHAT IS THE PURPOSE OF DVI-HDTV CABLE CONNECTIONS AND WHAT TYPE OF PICTURE DO I GET
The DVI cable was the early HDMI cable . all later sets have the HDMI port . when you had it hooked to a DVI source did you select that port with the remote ? if it did not function the port may be damaged . as to picture it should give you a HD quality picture that your cable box is broadcasting .
Dec 23, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where does the HDMI cable plug into for a Blue ray player?
i have the same tv. there is only a dvi input with separate audio inputs.you will need a dvi to hdmi adaptor to connect for hi def.hdmi is video and audio while dvi is only video.you still get the picture quality,but have to run audio rca cables also.
Jan 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
I have an r52wh74 tv. cant get it to display 720p
Hello Matiki64:
Yes this television does support 720p and 1080i. Hear is something that might solve your problem or at least get you going in the right direction.
Problems with DVI-HDTV Connection
• Make sure the DVI device is turned on and the cables are firmly connected. If problems still occur, turn off your device. Re-connect
your device. Reset the power by unplugging the power cord and plugging it back in.
• If you are tuned to the DVI-HDTV input and you’re receiving Unusable Signal message on-screen, contact the manufacturer of the
DVI device for further assistance.
• If you tune to the DVI-HDTV input and you see snow, the video goes in and out, or the video takes a long time to appear, your DVI
device is having trouble sending video information to the TV. Re-connect your device. Reset the power by unplugging the power
cord and plugging it back in. If problems persist, try connecting to the Y Pb Pr jacks instead if they are available or contact the
manufacturer of the DVI device for further assistance.
• If you have bars on each side of your picture, the device you connected might have a switch or a menu option allowing you to
change the picture format output that will fix this. Choose either 720p or 1080i.
Sep 22, 2009 | RCA Televison & Video
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Oct 15, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
