Question about Philips GOGEAR SA6045 MP3 Player
MP3 files will not transfer to my SA6045/02
When transfering music to my SA6045/02 with Media Player 11 they appear as unknown and show as wmpinfo file. This is a new problem and had worked previously. the media player also tends to hang at 100% complete.
All tracks had previously transfered with no problems.
I tried rolling back to media player 10 with the same problem. Although media player did show all tracks on the player but with the same results as above when i try to play back
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How to put music on
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Organize and transfer music and pictures with Windows Media Player11
4.1 About Windows Media Player 11
While your player will work with Windows Media Player 10, we suggest that you use
Windows Media Player 11 for a more enhanced media experience, both on the computer
and on your player.
Windows Media Player 11 is an all-in-one playback and recording program that lets you
play your CDs, rip CD tracks to your hard disk, transfer media files to your player, etc. This chapter describes the steps that you need to follow to successfully set up and transfer music and pictures to your player. For more information, see Windows Media Player Help on your computer or visit www.microsoft.com/windows/windowsmedia/player/faq/default.mspx
Important: Make sure that you have installed the Windows Media Player 11 software provided in the accompanying CD for music and picture transfer.
Although Windows Media Player also lets you transfer video files from your computer
to the player, please use the MediaConverter for Philips provided in the accompanying
CD for video transfers. For more information regarding transfer of videos, see 3.6
Transfer video.
4.2.1 Add music and picture files to Windows Media Player library
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
Add music and picture files that are stored elsewhere on your computer or
computer network
1 Select Start > All Programs > Windows Media Player to launch Windows Media
Player program.
2 Click the down arrow beneath the Library tab and select Add to Library ...
3 Click <<Advanced Options to expand the dialog box.
4 Click Add...
> Add folder dialog box appears.
5 Select a folder in which you have kept your music or picture files and click OK.
6 Return to Add to library dialog box and click OK.
> Windows Media Player will start scanning the folder and add available music or picture files
to the library.
7 Click Close when done.
Dec 28, 2010 | Philips GOGEAR SA6045 MP3 Player
Unable to transfer to mp3 player
Based on Philips SA6045 User's Guide, youou can transfer your media content in the following ways:
  • Using Windows Media Player 10 – Note: You cannot transfer all video files using this method. It is recommended to use Media Converter for Philips to transfer video files.
  • Using Windows Media Player 11 - Note: You cannot transfer all video files using this method. It is recommended to use Media Converter for Philips to transfer video files.
  • Using Windows Explorer - Note: While all files will transfer, they may not play back if the player does not support the format.
It is recommended that you use Media Converter for Philips to transfer your video content, and Windows Media Player (10 or 11) to transfer your music and pictures to the device. Use Windows Media Player (10 or 11) to transfer all video that you purchased online to the device.
CLICK HERE To download Media Converter For Philips
for further assistant, please check the User's Guide,
CLICK HERE To see the User's Guide for Philips SA6045
good luck :)
Apr 18, 2010 | Philips GOGEAR SA6045 MP3 Player
Suddenly my player can't transfer music files(mp3) (using windows media player). a message pops out saying that an unknown error occured/ player disconnected. im not even touching it while it's connected!...
Hi ! it´s a better idea to transfer you music using the explorer make a folder with your favorite music and then copy to the device if your device appears as a mass storage device.... ;)
Hope it helped
Jun 24, 2009 | Audio Players & Recorders
PC does not recognize ML648B in USB Mode
Switch the Player to MTP Mode instead.
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive.
• In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced.
• The difference with media files, specifically music files, is that they demand much more management.
• Downloading services can require special licensing and a limit on the number of playbacks a music file can have.
• The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
• For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP.
• Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center.
• We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Jan 27, 2009 | GPX ML648B MP3 Player
Mtp
  • The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive. In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive.
  • This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced. The difference with media files, specifically music files, is that they demand much more management. Downloading services can require special licensing and a limit on the number of playbacks a music file can have. The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
  • For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP. Those who have Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center. We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the button on the top of your player marked M
  • -Tha Mp3 Doctor
    Oct 29, 2008 | GPX MW3836 MP3 Player
    C cover art does not transfer to my zen vision m, only the music tracks transfer
    A few possibilities. Go to http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=224,E=0000000000373151655,K=1742,Sxi=15,Case=obj(8179),Kb=ww_english_add,VARSET=ws:http://us.creative.com/
    for more details
    Creative ZEN players do not currently support album art from Rhapsody version 4.0.
    Album art is either embedded in a track, or exists as a thumbnail image in a separate file, allowing one album art file to be associated with an album. Currently, Rhapsody only supports album art embedded in the track. Future versions of Rhapsody are expected to support thumbnail versions.
    Creative Media Explorer or Windows Media Player 10 or 11 can be used to transfer music purchased from Rhapsody to a player with album art included.
    Album Art is supported by Creative ZEN, Creative ZEN V Plus, ZEN V, Vision:M and ZEN Vision players.
    The ZEN Vision (PF1150) requires a firmware update for Album Art. You can download the updated firmware:
    If you experience any difficulty transferring Album Art with Windows Media Player 10 or 11, to ZEN Vision:M, delete WMPInfo.xml (see below), and then transfer the tracks again.
    -Tha Mp3 Doctor
    Apr 18, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Music
    You are trying to transfer a song that has download/play rights, but not media transfer or device synchronization rights. This is a very common problem nowadays. You may want to use a service like MediaMonkey to convert the songs to Mp3 format - but this program will not work with many copy-protected programs either.
    Mar 30, 2008 | Philips GOGEAR SA6045 MP3 Player
    Unknown Format
    It sounds like these wma files have DRM protection.
    You can still play these songs on your mp3 player, but you must use Windows Media Player to transfer them.
    To do this, connect your mp3 player to your computer, then open Windows Media Player. In WMP select "Sync" & you should see your mp3 player in the right-hand pane. Drag & drop your wma files across. It's a slow way to do it, but the only way to transfer wma files with DRM.
    Let me know how you get on!
    Jan 05, 2008 | Nextar MA566 MP3 Player
    Problem playing music files with new Goodmans mp3 player (GMP34G5)
    i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
    Dec 02, 2007 | GPX ML848B Digital Media Player
    Using Windows Media Player 11 or Real Player 10.5 to Transfer Music
    I have one of these too and it cannot be used with media player 11 as there are no updated drivers. Use media player 10 and you should have no problems.
    Jun 01, 2007 | Samsung Napster YH-920 MP3 Player
    Philips GOGEAR SA6045 MP3 Player Logo
    80 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
