Question about Canon LaserCLASS Fax 710 Printer
Can not receive fax on Canon Laser Calass 710 Faxmile.
I can Fax, I can copy, I can see when fax is trying to go through (memory light is blinking) but it does not print actual fax. On the sending end it gives an error. So fax is not going through.
This fax machine in on VOIP line.
Any ideas?
Thanks.
Alex
  • Anonymous Jan 06, 2009
    I have the same problem, does anyone know what to do, I know that we were do to change the toner?
  • sdainty Apr 14, 2009
    I have a Canon 710 and about 2 weeks ago it quit receiving faxes from certain pennsylvania numbers. The phone company has been looking into it but they cannot find a problem with the lines. Any suggestions???
It sounds like you need to adjust down the connection speed, and turn off error correction.
I'm not sure if it's the same as on the MF4270 I own, but on my machine you enter service menu by hitting "additional functions" followed by the pound sign. From there you can click through the options to find the transmit and receive speed options, and error correction mode option. The only real trick is entering service mode.
Posted on Sep 24, 2009
    Scholar:
  • 117 Answers
Line noise could cause trouble. I don't know if this unit supports VOIP phone lines. Many fax units require a genuine analog line or something that reproduces an analog phoneline.
Can you test the unit with a genuine analog line?
Posted on May 06, 2009
OUT OF MEMORY TRYING TO FAX
<Fax sending or copy operation in
progress>
Do one of the following:
- Press [Start] key to send or copy the
scanned pages.
- Press [Stop/Exit] key and wait until
the other operations in progress finish
and then try again.
- Clear the data from the memory.
<Printing operation in process>
- Reduce print resolution.
- Clear the faxes from the memory.
Apr 02, 2014 | Brother MFC 8950DW
My fax keeps printing the same fax continually. I have checked the other end and there fax is all OK. How do I make it stop?
It may be they have been sending the fax several times using ring back, if you go into the menu there is a setting to clear memory this should stop the copies.
Jul 18, 2011 | Brother FAX-2920 Plain Paper Laser
Received faxes, cartridge has run out how can I print or send to PC
some new fax machines has, fax memory older models dont, so if your fax machine is old. the fax has been lost, because when printing is one time (dont preserve on fax memory, only the comunication numbers. try talk to your fax senders send again a fax copy,
Jan 14, 2010 | Office Equipment & Supplies
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Problem with fax Memory
This could be very simple. Check to be EXTRA sure that your USB line is NOT plugged into the fax line. (There's a little phone icon). That's what happened to me....boy am i dumb!
Oct 02, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon LaserCLASS Fax 710 Printer Logo
529 people viewed this question
old marine
old marine
