Question about Vtech Lands Phones
At least three different times, the phone displayed "line in use" when it isn't. All jacks and plugs were checked and all troubleshooting tips in manual tried. Two other older linephones in our home had no dial tone during these times. Then the phones all start working again without us doing anything. Additionally, there is terrible static and crackling. The local phone company has been out twice, said the static was fixed, but it isn't.
    Top Expert:
  • Vtech Master
  • 81,342 Answers
Pull the power from all phones, and wait a few minutes and then plug them back in, if that doesn't work you have a defective base station most likely.
Posted on Jun 20, 2017
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Posted on Dec 22, 2007
SOURCE: bought phone EX18560 Series yesterday.
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Posted on Aug 16, 2008
divatif
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: telephone (land line) has no dial tone-- after a big rain storm
Let's make this official, then. Problem has to be in the modem or some piece of the cable or phone company outside equipment. You should get them back out for a closer look.
If this solution has been helpful, please take a moment to rate it. Thanks for asking here!
Posted on Mar 30, 2009
  • 279 Answers
SOURCE: no dial tone/ cordless phone says "searching"
Go to http://www.home-electronics.net/ge/pc/user-manuals.asp They have the manual there
Posted on Sep 19, 2009
My Uniden handset is not working. No dial tone. Just a long continuous beep. Unable to ring out or receive incoming calls. How can I troubleshoot this problem.
open line if have more than one phone plugged into a jack unplug one at a time and check dial tone if no change have phone company check incoming line
Jun 01, 2018 | Uniden Lands Phones
My display says no line,i have checked my line and fitted different cable but still saya no line
Plug another phone into the phone jack in the wall does it work?
Oct 11, 2016 | Lands Phones
Phone displays error message "check tel line
The phone is not detecting dial tone on the line. Are you able to hear a dial tone? If not - disconnect the cable at the phone and plug into a different phone. If it works, then the problem is with the Panasonic phone - if it doesn't work - the problem is with the cable, jack, wiring, etc.
Mar 12, 2015 | Panasonic Lands Phones
My KX-TG6511 Phone is in it's cradle but line in use message shows. It's the only one on that line
Check your phone line with a) a new cord between the base and the jack and b) a different phone (I prefer an old cordless phone). If you still get a "line in use" message (alternate errors: fast busy signal or no dial tone), use your test phone at a different jack and determine if the issue persists. If you can, find where your phone service comes in and open the box. If you are lucky and have a fairly new service connection, you'll be able to plug your RJ-11 phone line in and check if there is the problem is at the box. If you can't test at this point, you need to contact your phone company to diagnose if the problem is inside or outside.
If the problem is only with the KX-TG65111 phone, try unplugging the base from the phone line and the cord from the wall jack, disconnecting the base AC power cord (from both sides - phone first) and removing the batteries the handset. After a few minutes, plug in phone line, power cord and batteries and test again. If it still fails, then the phone needs service. These cordless phones are not designed for the home user to service. If the phone is under warranty, contact Panasonic. Otherwise, decide if it is worth having the unit serviced or replacing.
If no phone works at this one jack but does work at another jack, you have a wiring problem at the jack or in the wall to the jack. Try opening up the outlet and check for loose or damaged wires. The jack is either wired directly to screw terminals or punch down terminals. For the screws, it's relatively easy to strip the insulation and retighten the connections. For the punch down style, you will need the appropriate tool. (It's available from many hardware stores in the wiring section.) See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the pins in the jack wiring.
If none of your inside jacks work, look at the exposed wiring and check for any obvious damage. Otherwise, you'll need to find the problem in the walls. You may want a professional to do the job.
If the problem is outside, your phone company will fix the probem for you for free. If the problem is inside, they'll fix the problem for a fee.
If you have a DSL line and a filter on the line, check and replace that if it is part of your inside wiring.
I hope this helps.
(I've gotten a line in use error with a DSL filter problem after a nearby lightning strike. Since my filter is inside the service box, my telephone company handled the repair.)
Nov 21, 2011 | Panasonic KX TG6511 Cordless Phone
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    I have Linksys spa-942 phone. its display not working. i want to know about current ip address of this phone. is it any way to listen ip address through this phone?
    Easiest way to troubleshoot this would be with a second phone. Plug another phone into the line, if the phone works then you know the problem is with the original phone. If the other test phone isn't working then it would be either the cable running from the phone to the wall, the wall jack, cable running from wall jack to the PBX or VoIP modem.
    Comment back if you need further assistance.
    Aug 18, 2011 | Linksys SPA942 IP Phone
    I have an emergency and my phones are reading ''line in use'' please help me
    unplug all phones on the lines and everything else possible plugged in , then try using a different home (wired) phone to one jack. if it is okay, one wire or phone is bad. then try different phones one at a time to see if it clears. this will troubleshoot which part is bad. let me know.
    Oct 30, 2009 | GE Telephone pr521w
    Second line not working
    The phone will show that "line in use" message when it's not connected correctly.
    If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
    If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
    If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
    Dec 10, 2008 | AT&T E2562 Cordless Phone
    SHARP UX-B750 facsimile will not receive faxes and displays the message "NO SERVICE".
    Plug a regular phone into the wall jack and listen for a dial tone.
    Make sure you are plugged into the LINE port of your fax machine.
    Do you have DSL phone service?
    Oct 21, 2008 | Office Equipment & Supplies
    Panasonic Panafax UF-885
    If there are two RJ-11 jacks on the fax machine you need to make sure that the line from the wall is plugged into the LINE jack not the TEL jack. If that is not it let me know and I will provide you some troubleshooting instructions from the factory service manual.
    Sep 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
    Lands Phones Logo
    49 people viewed this question
    Top Vtech Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
