Question about Canon PowerShot S2 IS Digital Camera
My lens won't come out.
I have a canon powershot S1 IS and it was dropped on a vacation trip. i tried turning it back on to see if it was working fine and this orange light turns on instead of the usual green light that indicates it's turning on. i can hear the lens trying to get out but it won't. when i go to display mode to view the pictures in my card, the camera works fine, so the everytrhing works fine except the lens not coming out. help!!!
  • 641 Answers
It sound like the lens mechanism was damaged during camera's drop. Only way (to my regret)is to sent it to be repaired in a professional lab.
Posted on Aug 01, 2007
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
I have a brand-new Canon PowerShot A2100 IS that is having lens problems. The lens didn't retract when I turned it off. When I turn on, all it say is LENS ERROR, RESTART CAMERA. When I restart it, it's...
In the compartment where the batteries go, there is another smaller watch battery, pull out the watch battery, and re install, and that should fix your lens error, I have a Canon powershot A700 that was getting the same error code and it works just fine now!!
Jul 21, 2009 | Canon Cameras
Black screen on Canon S1 IS camera
If Canon S1 IS does not show picture in camera mode and show memory card stored pictures in playback then its CCD Imgaer problem and ccd imager will be replaced.
Canon will repair it free of cost, click Canon CCD Imager Advisory for details.
Jun 11, 2009 | Canon PowerShot S1 IS Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
Lens gets jammed on and off
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Canon PowerShot S1 IS Digital Camera
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
Canon pwershot s1 IS E18 error code
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Sep 14, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
