Question about Canon PowerShot A75 Digital Camera
Powershot SD870 IS digital elf will not focus
Preschooler messed with the camera. Everything in the view finder is blurry. I have tried resetting in the menu and also have tried to turn on or off every option in the menus in order to fix the problem. The troubleshooting tips in the manual have not worked for me. Please advise. Thank you.
  • ksrb Nov 18, 2008
    I really appreciate your thoughts. Thank you. Signed, Blurry-eyed.
    Novelist:
  • 100 Answers
If you've done all those steps, I would look at the physical attributes of the camera. Does the screen have gunk on it? How about the lens itself? You might also check to make sure the camera isn't set to video mode. In low light, that could make the view screen look a bit blurry.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
Nov 23, 2013 | Canon EOS 60D Digital Camera with 18135mm...
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
Canon PowerShot SD1400 takes more blurry pictures than clear
Well make sure you focus the camera and without leaving the shutter buton click it.Dont let the camera re focus. Also View the the image from the view finder ( digital).If not reset the camera.
Nov 13, 2011 | Canon PowerShot SD1400 IS IXUS 130...
I have a canon powershot sx20..looking through the view finder looks blurry,but after takingt the picture and looking on the screen the picture does NOT look blurry...It's only blurry when looking through...
Your camera is equipped with a optical diopter that will allow you to adjust the optics in the viewfinder to your eye. meaning bringing everything into focus as it should. The way I use this (set it) is to let the camera auto focus on a subject and then turn the diopter until I see the subject clearly.
It really helps if the subject is about 12 feet away (get it real sharp) and the camera is mounted on a tripod. Once set I put a little dot of paper white out on the diopter adjustment knob so if it gets turned I know and can quickly return it to the correct spot. I'm including a diagram where this adjustment knob is on your camera, have fun.
Diagram
Jan 22, 2011 | Canon PowerShot S3 IS Digital Camera
When I look through the viewfinder on my Nikon D40x it is blurry and looks out of focus, but when but after I take the picture it is clear on the lcd screen. Is there a setting I can change or is something...
Adjust view finder focus as you will see setting there, to view correct focus in view finder itself.
Camera is just fine because it is taking good focus pictures.
Oct 17, 2010 | Nikon D40x Digital Camera
Problem with flash on Canon Powershot SD870 Digital Elf
There is a problem with the flash or flash charge circuit. It will need to be repaired and may cost about $ 100 if not under warranty,
Apr 05, 2010 | Canon PowerShot SD870 IS Digital Camera
All of a sudden everything is out of focus and very blurry, pictures and even through the view finder. we took a few pics tht turned out normal, set the camera down picked it up about 5-10 minutes later...
If the viewfinder is also blurry, it might be as simple as a smudge on the lens. Is the blur uniform and consistent on the pictures and in the viewfinder? Was there a curious dog nearby when you set the camera down?:)
Sep 20, 2009 | Sony Cameras
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
View finder not functioning properly
you have to focus it using the round knob on the lens side...see it?
Jan 06, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
Blurry pictures
Try differential focus That is point to something near the distance you want- half depress the button -turn to subject complete the press down Bear in mind that if the subject is really close to the view finder is not looking where the focus window is-Parallax- learn to shift you frame slightly to allow for this.
May 13, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
