Question about Grohe Satin Nickel Soap Dispenser...
Grohe soap dispenser stays in down position. What can I do?
Thanks,
Pauline
You have got to be kidding. I pay to get a solution from you and you get a free solution from me, so that, you can charge someone else. Ha!
I thought you were part of the Grohe web site until I saw the charge.
Grohe is taking care of me fine thank you.
Posted on Nov 18, 2008
Grohe soap dispenser 28.857 leaks
Take it apart and clean it. If that doesn't work consider replacing it.
Nov 30, 2013 | Grohe Deluxe L Soap Dispenser Finish:...
My soap dispenser wont pump soap
Are you out of soap? Does the pump go freely up and down? If the pump goes down a little and then stops its probably clogged. If this is the case just get a long piece of notebook wire and slide it through the pump and it may unclog it. Really a soap pump is a very simple set-up. Suction from one end brings the soap through the tube and out the actual dispenser. Hope this was helpful:)
Sep 20, 2012 | Grohe Soap Dispenser for Kitchen...
I have a Grohe liquid soap dispenser and the washer is leaking soap at the base of the unit. can this washer be replaced?
it is not available from Grohe but if you take it apart it is probably generic enough to be found at your local hardware store. assuming this the problem. it may just need to be tightened up a little. either way here is a link, w/an adobe file (specification sheet), regarding the specs about 1/3 down the page on the left. you can also purchase the soap dispenser here. hope this helps:)
http://www.faucetdirect.com/grohe-28-751-deck-mounted-soap-dispenser/p54966
Jul 26, 2011 | Grohe Soap/Lotion Dispenser 28.857.AV0
My Grohe soap dispenser leaks under the sink. The bottle simply hangs off the pump. It looks like it should screw on the dispenser but there was no nut. Is this correct?
Virtually all soap/lotion bottles have threads on the top of the bottle and are designed for initial installation only since all if them are refillable by pulling up on the pump head. Grab the bottle and twist to the right. If it will not tighten then the threads are stripped out and complet dispenser replacement is required. Grohe does not sell either the pump assembly nor the bottle separately.
Sep 28, 2010 | Grohe Satin Nickel Soap Dispenser...
Dispenser will not press down
Unfortunelately for you, Grohe, does not offer pump head replacement to the best of my knowledge. The entire pump/bottle therefore will have to be purchased. You didn't mention what finish you had so if you plan to stay where you are for a long time I would suggest you look at the Rohl soap dispensers as an alternative. Their warranty is for 10 years and you can run a 3/8" I.D. vinyl tubing from the pump down to any size jug of soap you want under the sink and never have to refill it again from above. The finish might not be a match however.
May 28, 2010 | Grohe Satin Nickel Soap Dispenser...
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
I have a Grohe dish soap dispenser that get clogged-? soap
Dilute the soap you use by 1/3 . this won't affect the soaps ability to clean, but it makes it easier on the dispenser.
Jan 16, 2018 | Whirlpool GU2400XTP Built-in Dishwasher
Bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
Grohe Satin Nickel Soap Dispenser... Logo
848 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
