Question about Compaq Presario 700 470024-192 Notebook
Prob. 1unit shuts off by itself/ prob 2.back is cracking again
Prob. 1. While using and in middle of work, the screen goes dead, both power lights go out. I hold power button down for 8 seconds and sometimes it comes back on. Some times when I try and power for the first time the power will not come on again I hold power button down for the 8sec if I am lucky it powers up.
prob.2. the back of the screen is cracking for the second time the warranty is no longer in affect . I think this must be a lemon B/C it is the second time this has happened do I have any recourse
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    do you mean the screen its self cracked or the plasics?
I thing your lap top over heating.clean the cooling fan / heat sink and air outlet..it will work...
Posted on May 29, 2012
    Problem Solver:
  • 10 Answers
IT SOUNDS TO ME LIKE THAT YOUR UNIT IS OVER HEATING WHICH IS VERY COMMON WITH CHEAPER LAP TOPS. YOU CAN GO GET A LAP COOLER FROM STAPLES OR A LOCAL ELECTRONIC STORE THEY ARE NOT VERY MUCH. DID YOU DROP IT?
Posted on Nov 24, 2008
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
I don't have the remote but the screen comes on for 1 second and then goes black again. Power light is on and not blinking
Your tv is shutting itself back down because it is protecting itself from further damage from an internal issue. U might want to check the power supply for proper operation since is a common source of hassles.
Sep 25, 2015 | Televison & Video
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
HP Pavilion zv6000 power issue. My laptop fan kicks into high gear whenever the adapter is plugged in. Frequently it suddenly shuts off completely to keep itself from overheating. If I use battery-only...
the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Aug 04, 2017 | HP Pavilion zv6000 Notebook
Game stuck/blinking red light
i was playing mw2 yesterday and bam (red light of death) ill prob have to send it to sony but i got the game out follow these steps. 1. turn off at the back. 2. hold your finger on the eject button. 3. turn on again at the back while holding the eject button for a few seconds 4.your playstation should start up and your game should be ejected
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Monitors goes black - Hyundai Q17
I had the same problem some time ago.
After dismateling the power-supply unit it apeared that there was en crack in a solderjoint at one of the power transistors. This transistor has 3 legs (TO220 I believe), from which the middle leg had a solder crack, probebly due to thermal stress. Just resolder and it worked again....
Its worth a try I think.
Succes,  Wim Steenhuis.
Oct 04, 2006 | Hyundai ImageQuest Q17 17" LCD Monitor
Compaq Presario 700 470024-192 Notebook Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
