Question about Pioneer PRO-710HD 64" Rear Projection Television
Mirror Installation We were given this enormous t.v. and could not fit it in the 60+ year old house we live in with tight corners and small openings, without removing the back, which we did, not knowing that the back secures the mirror. The mirror fell (but didn't break). We don't have a manual and don't know if it is possible, but we need to find a way to remove the screen to reinstall the mirror. Sadly, the only way this t.v. is going to come out of the house is in pieces, so we would really like to find a way to make it work. Any advice would be greatly appreciated!
  • 3 Answers
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Posted on Oct 13, 2010
2010 SLT Acadia. replacing front head lamp. found empty light bulb housing both sides with plugs.
On most vehicles there are 3 blinker bulbs on each side. One at the front corner, one at the rear corner and a third side repeater usually mounted in the front wing, (fender).
Some more modern car companies have started fitting the side repeater into the door mounted 'wing' mirror body.
The blink rate will usually be around 60 to 120 flashes per minute. If the rate on yours is usually slower, a higher speed flash suggests there is a blown or missing bulb.
May 17, 2018 | GMC Acadia Cars & Trucks
How old is a 10 year old dog in human years
About 70, though it can vary from breed to breed.
Jan 07, 2017 | Dogs
How to replace outside side power mirrors in original housing? 2008 Ford Edge
Google replacement mirror glass for Ford Edge 08.
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
26182860-kzssal3k2qlm4jsc53ab1s2h-2-0.jpg This is an easy repair.
How to Repair and Replace Broken Side Mirror Glass DIY
May 02, 2016 | 2008 Ford Edge SEL
How do I install a driver-side power mirror?
Start by getting an "easyout" kit for the screws that held the old one in. You may need a small drill to start the easyout, but that will let you remove the old one cleanly.
You may be able to splice the wires inside the door, or run the wires from the new mirror into the car somewhere. . .
May 20, 2015 | 2002 Mercury Cougar
Is the internet article about the 60 year old pristene house true. It says it wasnt lived in for 60 years and yet still has pristine appliances. What happened to rust?
If you mean the kitchen with the pink exterior, you might want to ask the person that bought the house in 2010 directly. He's still selling the unused appliances.
Feb 24, 2015 | Cars & Trucks
I have a dual wall heater at least 30 years old (was in place when I moved in) but could be as old as house 60 years old. Heater works just fine, does good job of heating house (montgomery ward model SFB...
Soot is a sign of incomplete combustion. Cleaning may or may not fix the root cause of this, and given the age/efficiency of the unit, I recommend replacement. If you do have it cleaned, be sure to have the combustion checked.
As to whether this is a DIY project is dependent upon your personal skills, but the fact that you asked is (sorry) a strong indication you should not attempt this job yourself. Hope this helps.
Feb 20, 2015 | Heating & Cooling
Water & Ice Maker installation schematics. Need diagram of back of refrigerator
You need to get the model number... look up the DUAL water valves (which seem to be missing) and hook up the water & ice RESPECTIVELY
Watch those supplier videos...
Those new press connectors are a snap to
use (and release)...
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
kit LIKE THIS... (can't tell w/o model number)
Amazon com 2181730 Quality Replacement Dual Water Valve Kit for...
Carnac the Magnificent
May 21, 2017 | Amana Refrigerators
How do you fit an 06 Range Rover door mirror?
Is there three plastic caps about where the bolts re or does it have the little plastic trinagle cover over the corner of the mirror?
Jan 22, 2010 | 2006 Land Rover Range Rover
2003 GMC sierra side view mirror glass replacement
That dependso on if the housing itself is broken then yes. If the face plate that is attached to the mirror itself is flapping around then maybe. If it is just the mirror, just go to your neighborhood auto glass shop and but a "Ready-Cut" mirror for a small amount of money. they come already cut to fit perfectly. As for removing the old glass, take a very small flat screw driver and pry the glass away from the face plate. Once completely cleaned out use the adhesive from the ready cut and place them on the face plate. Next press the new mirror onto the flace pate, being careful not to press to hard or it will snap it in half.
Jun 03, 2009 | 2003 GMC Sierra 1500
2005 Ford F-350 mirror installation
It sounds like you bought the wrong year mirrors. Yes you could cut the connector off you old mirror but you would have to know the wiring for the mirror not the truck.
Apr 12, 2009 | 2005 Ford F 250 Super Duty
Pioneer PRO-710HD 64" Rear Projection Television Logo
74 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
