What is the difference between deep copy and shallow copy
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you give us more information please
    President:
  • 2,992 Answers
A deep copy makes a completely new independent copy of an object, including copies of any other objects it references. In a shallow copy, only references to other objects are copied, so the copy and the original may both reference the same object. The copy is not a completely separate duplicate. Google "deep copy vs shallow copy" for the language you're using. There are a lot of websites you can visit for information and examples.
Posted on Nov 19, 2008
What is the difference between roasting pans and broilers?
Roasting pants are for big peicesof meat becuase they are big, deep pans so the meat will cook and be flavoured from its juice.
A broiler has shallow sides so the meat cooks faster. It also has a slotted bottom so the pan drains.
Jan 14, 2013 | Home
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
How will i know if my ford explorer has a deep or shallow transmission pan
If it is a two wheel drive,most likely has shallow pan has the deep pan.But measure the deepness of the pan.Put the ruler beside the one of the bolts on the pan.If it is over 2 and 1/4 inch deep,it is the deep pan.Hope fully this will help.
Oct 09, 2009 | 1998 Ford Explorer
Mix sm amount of caustic soda for deepwell
In most cases caustic soda is used for the treatment of large commercial deep wells. Unless you have a specific problem, (neutralizing a high acid level) that requires it or are treating a large turbine powered deep well system you really should use either a powdered or liquid chlorine. Also if the caustic acid can help promote oxidation which could adversely affect the pump.
I have sunk several shallow wells and replaced as many deep well pumps and never used anything other then about 1/2 gallon of chlorine. I included a link to a great site for information on the treatment deep and shallow water wells.
Hope this helps.
http://www.inspect-ny.com/water/Well_Shock_Procedure.htm
Oct 07, 2009 | Plumbing
Can a shallow water pump be converted to a deep water pump?
No, if it is a true shallow well jet pump it may not be converted to a deep-well. A deep well may be converted to shallow well.
I hope this may have helped,
Tom
Sep 21, 2009 | Plumbing
Doesn't clean shallow end
try aiming the return ports to direct the cleaner to the shallow end
Jul 31, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
TRANSMISSION OIL PAN
the depth of the tranny pan isn't really important. if you want to check the fluid let the vehicle idle and check it while its running unless its manual than you'll have to do it from underneath
Feb 17, 2009 | GMC Jimmy Cars & Trucks
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
