Question about OKI C5100n Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
What does the 380: paper jam indicate. I have search everywhere to find a piece of paper jammed in the machine and cannot find any. Any suggestions!
  • 1 more comment
  • amirisa66 Dec 06, 2008
    OKI C3200N Laser Printer
    Flashing light Error Msg 380: Paper Jam eventough I already removed
    the jammed paper from the drum inside.
    Pls help!!
  • andresbj Jan 29, 2009
    The printer says it jams only when i print from the main paper tray. I have removed, cleaned and relaced: toner, image drums and fuser kit. Even turned printer upside down trying to blow out any paper pieces with compressed air.
    It prints from the Manual Feed Tray with out any problem, if and only if, i remove the main paper tray completely. If the main tray is in place, it tries to feed paper but fails almost instantly.
    Any suggestions?
  • Anonymous Mar 18, 2014
    error 380 paper jam oki
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Posted on Dec 02, 2008
I've just cured the same issue.
Inspired by MCS-IT, I fed a sheet of paper into the paper path (printer over the edge of the desk) popped open the front cover and manually drew the paper through by turning the cog wheels. Voi-la (sorry French spelling not a strong point) a small piece of ripped paper was forced out!
Posted on Feb 21, 2009
  • derek75 Apr 27, 2011
    Brilliant idea. This method does work, you may have to try a few times to nudge it through. It's usually just a small piece of paper around 1" square that causes the problem.
When clearing a paper jam, it is possible for the offending piece of paper to tear and a small piece to be left inside the machine.
If the jam occurred in the paper inlet path, it is quite possible that any paper left behind will be jammed on the lever which operates the inlet sensor. This will result in the 380: paper jam message.
If you slide the front of the printer over the edge of the desk and look up from underneath, it will be possible to see the paper entry path and the lever which operates the sensor. If there is any paper here, it should be visible and can be removed with long tweezers or needle nose pliers. Taking care not to damage the lever itself.
Unfortunately, this area is not visible from any other direction, which IMO is a design fault.
Posted on Dec 08, 2008
  • 624 Answers
You probably have already looked this up by just in case here is Okidatas instructions for clearing this jam: http://my.okidata.com/PP-C5100n.nsf?opendatabase. If you have already looked here and done this then I would suggest: -Open and close the rear cover. -Pull out and replace each of the toner cartridges. -Pull out the duplexer, ensure it is clear of jams and replace. -Pull out each of the paper trays (including the manual tray), ensure paper is installed correctly and replace. -Close the top cover. Per Okidata this has to be done last or else you will continue to see a jam error. -Try unplugging the printer and letting it set for a few minutes and retry. If that fails you might try purchasing a can of air from the computer store (about $3) and blow out the paper path to clear any paper or dust that may be blocking an optical sensor.
Posted on Dec 03, 2006
Make sure, repeat make sure, the paper path (rollers) are clear of even the smallest piece of paper. If not, the printer will continue to show the error message.
Posted on May 16, 2008
Make sure you clear the rollers of even the smallest piece of paper or it will not clear the jam.
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Display says " open front cover"
where the rollers are located is a small electric eye sensor that detects the paper, I would almost put money on it that there is dirt of some kind down in there, and it is blocking the sensor, so it says "jam" even if there isn't any paper in the printer at all. Give it a real good cleaning in that area and all should work as it is supposed to.
Dec 15, 2010 | OKI C5100 Laser Printer
380 paper jam
Pull out the toner&drums and see if its under there
Oct 08, 2009 | OKI C3200n Led Printer
Alledged Paper Jam
Check underneath the toner/drums for the paper.
Oct 06, 2009 | OKI C3200n Led Printer
I have a C5100 laser printer and have some paper jammed but can't get to it. HELP!!!
you can get it to the back of your printer
i hope i ca solve your problem
Sep 01, 2009 | OKI C5100n Laser Printer
Error Code #380
check in back side of printer there should be small paper jam check it.
Jul 13, 2009 | OKI C5100n Laser Printer
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Apr 09, 2009 | OKI C5250n Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI C5100n Laser Printer Logo
5,362 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
