Question about Lexmark Z615 InkJet Printer
Indicates incorrect ink levels
Lexmark z615 with windows vista.. install new ink cartridges but ink status still indicates old cartridge levels after carrying out new cartridge instructions.
i want = Driver Printer Lexmark z615
Posted on Jan 29, 2009
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
Installed correctly working in order.. says ther is ink left in cartridge but they are very old and the printer is printing.. just with no ink on the page.. dont want to buy new ink as it is expensive and...
One would expect that the ink is dry or that the sensor on the cartrdige is sending incorrect information, if you say the cartridge is dry. If it was new and empty you could consider getting a refill kit but probably won't help you. Contact your local pc shop and see what their cheapet printers cost - with cartridges. Could be cheaper than one cartridge!
Feb 11, 2010 | Lexmark Z615 InkJet Printer
Lexmark X3650 all-in-one Printer, have refilled colour cartridge with inkjet refill kit but still indicates low-ink level, and will not function. Do I need a resetter?
Go to all in one program
at the top left click on Maintain\Troubleshoot
Right window click on Device Status And Ink Levels
that will open a new window
Click on The button that looks like 4 different colored ink drops
Click on Install a new print cartridge
Click on Next
Now you should be in Select The cartridge installed
Open lower drop down window and click on No its new
Follow the prompts from there or click OK
This should fix the problem.
Oct 21, 2009 | Lexmark X3650 Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Resett ink levels
are the cartridges resettable after a refill ?
Jan 02, 2008 | Lexmark P4350 All-In-One InkJet Printer
My lexmark printer wont print color
need the drive j ' install print lexmark z615
Jan 10, 2007 | Lexmark Z615 InkJet Printer
Lexmark Z615 InkJet Printer Logo
157 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
