Unable to connect to the internet I need an address for my smtp
  • 1,879 Answers
SMTP is for email. If your email is provided by your ISP, you need to get the details from them.
Here's a Google POP settings example:
Posted on Nov 17, 2008
How to configure gmail SMTP setting for outgoing server?
Process to configure gmail SMTP setting for outgoing server
Gmail provides email services to user.It is used for sending and receiving mail.It is freely used by users.It is developed by Google.If you create an account an G mail then you can directly open your Google account there is o need to create another account. It provides unlimited space to user. For some Business application Gmail is used as paid .Gmail is used as open source.
When you use Gmail then you need to check that your server is connected to Gmail or not.You should know that Gmail SMTP server is used for sending email from your Gmail account. SMTP is Simple Mail Transfer Protocol ,it is used for every email account but it is not same for all the accounts.so for Gmail Account you need to configure Gmail SMTP settings then you need to follow these steps:
First you need to go in the Email client software then you have to go in the outgoing mail
first you need to check that your Gmail SMTP server Address that should be SMTP.gmail.com.
Then you have to enter your Gmail SMTP user name ,your SMTP user name should be same as your Gmail address.
Then You have to enter SMTP Gmail password,it will be your Gmail password.
Now you have to enter Gmail SMTP port number for TLS and secure socket layer connection.
Then you have to select "Use SMTP authentication".
Then you have to click on YES if if you see that Gmail SMTP TLS/SSL required.
Then your SMTP server will be set to your Gmail client.
You can easily configure your SMTP Gmail Setting with the use of above steps but if still you are not able to configure your SMTP settings then you can contact Gmail Technical Support for any query .They will provide you best solution.
GET INSTANT SUPPORT FOR YOUR GMAIL ISSUES NOW
Jun 15, 2017 | Computers & Internet
Hotmail account can't connect to the server. tried all advise with pop3
The outgoing server probably requires authentication (usually the same password as for the incoming server). Is your email client sending authentication? Look for a checkbox saying something like: "Outgoing server requires authentication."
Also, I just want to make sure that you can't use "smtp.live.com-25-TLS as the address for your server. The server is smtp.live.com, the port is 25 and encryption is TLS.
Oct 22, 2017 | PANDIGITAL Novel 7
Scan to e-mail
Hello
To be able to scan to email, your machine must have the correct hardware.
The following addon board and kits must be fitted:
1 Network Printer Kit [In South Africa we use the GA 1190]
2 Scanner Upgrade Kit [In South Africa we use the GA 1200]
3 Extended Keyboard [In South Africa we use the GJ 1040]
Once the hardware is fitted to the machine there are a few more steps to follow:
1 The machine must be connected to the network. [network must be on the internet]
2 An IP address, Subnet Mask and the Default gate way must be entered in the machine.
3 The DNS server must be entered through your internet browser.
4 The SMTP address must be entered through your internet browser.
5 The SMTP client must be entered with a valid email address through your internet browser.
6 The email section must be setup in the internet browser.
That should do it for you.
Regards
Apr 25, 2011 | Toshiba E-Studio167 Copier
I can't configure the email. I enter the SMTP address but wet I try to connect tell me Conn. Failed , I don't now how to configure it and where if is i have to put the information about my internet...
SMTP2Go has an SMTP server that works with Xerox WorkCentres:
http://www.smtp2go.com/blog/smtp-server-for-xerox-workcentres/
You can also test their service for free.
Sep 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Can recieve e mails,cannot send or reply to in-comming mail.all messages come up as failed delivery.no problem when first connected
1. Change the settings in your email software so that the email account you're using designates an Outgoing Email Service that your internet service provider won't block. Your internet service provider should provide you with the address of an acceptable Outgoing SMTP Mail Server. This information is often listed on their website; if it isn't, call their technical support and ask them the address of their Outgoing Email Server. Then go into your email software and change your current Outgoing SMTP Address to the one your ISP requires.
2. After you designate a SMTP address not restricted by your ISP, you may still receive the following error:
Port: 25, Secure(SSL): No, Server Error: 530, Error Number: 0x800CCC78
Now you are reaching the Outgoing SMTP Mail Server, but it won't process your request without further authorization. You will need to go into your Email Software and find the setting that indicates that your Outgoing SMTP requires further authorization. Select this setting and enter the username and password required by your ISP (or reqired by who ever is the administrator of the Outgoing SMTP Mail Server that's not blocked by your ISP). For example, at the time this article was written MSN Internet Service's SMTP Address was: (secure.smtp.email.msn.com). However, this email server won't allow you to use it unless you send your MSN username and password along with your request to send email.
Feb 22, 2010 | Computers & Internet
Scan to email gives server response error in home network. SMTP server tried by IP address and DNS name. Port 25 Authorisation POP for SMTP. The other authorisation types give a network error straight...
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Feb 20, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
I cannot send mail on my MacBook Pro (Intel) using OS X's Mail program at home using my 2wire; it works at the office on Cable. What's wrong with my settings and is it software or hardware?
You may be using the wrong SMTP address for the Outgoing mail server address for your email service.
If you are not sure what your SMTP Outgoing Mail Server address is, then you can reference this link
below, to locate the Outgoing mail server address of your current email service provider
Link: POP & SMTP Email Server Addresses
In regards to checking your mail settings in Mac OS X Mail you will need to perform these few steps:
*Launch Mail
• Click on Mail name and select Preferences from
the drop down menu.
• Now select the Account tab.
• Locate your affected email account from the side
bar and from Account Information, make sure
your Outgoing mail server address is correct.
I am using a .Mac account as an example,
but the same principal applies.
Now if you do find that the Outgoing mail server address for your email service is correct, then the issue may be with the SMTP server for your email service.
One way to determine SMTP functionality however, is to go online and use the web mail page for your email account and send out a test email.
I would also recommend you make sure your Macbook Pro also has the most current version update.
Apple usually has bug fixes in each of their version updates for the Mac OS X Mail application, as well as other built in Mac OS X applications.
If you are still unable to send outgoing mail, contact your service provider to get more assistance and have them check your SMTP server address, authentication and connection with their Outgoing Mail servers.
Regards,
-Mactechtrainer
Feb 01, 2010 | 2wire (1000-000057-000) Modem
I can't get exchange to smtp out. godaddy was the email host but they weren't very helpful and change MX to point to my server. Now it's worse... can't get incoming or outgoing.
1. The mx record has to be changed to an adress, which can be reached from the internet. It has to be an public IP Adress or you have to use dyndns.org or something like that. If the Server is not reachable directly in the Internet, you have to set your Internetrouter to forward smtp to your server in your network.
2. There are cases, when you need to configure a Smart Host for your e-mail server. A typical example is the situation, when your ISP blocks outbound connections on TCP port 25. Another, very common case is when you are using an IP address which belongs to a range of Dynamic IP addresses. It is a common practice to drop smtp connections or discard e-mail messages sent from a dynamic IP address.
a. Open your Exchange System Management Console - Administrative Groups - "Groupname" - Server - "Servername" - protocols - smtp.
b. Click right to"virtual standard server for smtp" and choose properties.
c. Change to tab delivery.
d. Then choose the button advanced.
Here you can set the full qualified domain name and you can set a smarthost entry. May be this helps
take also a look at http://codebetter.com/blogs/john.papa/archive/2007/04/02/Problems-Sending-Mail-on-Dedicated-Server-with-GoDaddy.aspx
May 22, 2009 | Computers & Internet
Mozilla Thunderbird setup
    Google Gmail Outgoing Mail Server (SMTP): smtp.gmail.com
    The Gmail SMTP server requires authentication (use the same settings as for the incoming mail server)
    The Google Gmail SMTP Server requires an encrypted connection (SSL) on port 465.
    GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
      Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
Sep 21, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
