Question about Kenwood VR-6070 Receiver
Starting system cold, no sound for 2-3 minutes
I've had my Kenwood VR6070 for about 4 1/2 yrs now. Just recently when I go turn my system on to watch TV, a DVD movie, listen to the stereo or just play a CD no sound comes from any of my speakers and my auto detect is not detecting the signal. But, once the system warms up everything starts working as normal. I can power off the unit and turn it back on within 20 seconds and everything is working great, but if I start the unit cold that is when I seem to have the problem. Nothing has been added or changed within the last year. I reset the microcomputer with hopes it would resolve my problem, but it did not. Has anyone experienced this problem before? Not really sure what to do, or if it's een worth getting it looked at. Thank you for your time and assistance! Jeff
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Posted on Feb 09, 2009
Recently purchased a second hand spa but having problems getting it to run. Jets run perfectly for a period of 4 minutes and cut out but power still goes to the motor and causes a humming sound.
Normally I would tell you to check your warranty (but seems you don't have manual)
* Check panels and equipment for contact number and call for support.
*** Following is for information only.***
* Sounds like a restriction in output of pump system.
* Do not allow a "Humming" pump to continue operation. Burn out may occur. Turn off power.
* Need to check the water flow. Start from suction intake.
* Check screen and clean.
* Check intake hose(s) for obstructions or restrictions.
* Is there sharp bends or weakness in hose. It should be a ridged pipe with no sagging or squishy parts. (It will collapse during high suction.)
* Check the intake manifold and shutoff valves for operation. (all intake valves should be fully open when in use.)
* Keep following water pipe (flow) to filter basket(s) then pump. Check and clean.
* Output may have a manifold valve system. Check and clear. Confirm the output is directed back to pool.
* Suggest contacting your local pool service for additional advice.
* The following has more detail in pool operation. (may void warranty.)
* Do's and Don'ts; https://www.youtube.com/watch?v=814U-6K5-48
* Basic pool Maint.; https://www.youtube.com/watch?v=lEfMxFE_n8E
* Cleaning impeller; https://www.youtube.com/watch?v=aFcNIoQDf4s
* Backwash; https://www.youtube.com/watch?v=21oPUwgMsQE
* Priming pool pump (starting); https://www.youtube.com/watch?v=V2_5fQ6ixzY
* Repair; https://www.youtube.com/watch?v=Gg3nGJplshs
Aloha, ukeboy57
Aug 07, 2018 | Universal Pool & Spa
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
98 VW Beetle AC acting up I have a 98 VW Beetle
without putting my machine on it and extracting the gas to see how much gas their is by weight then i couldnt even think of a reason for this sorry
Sep 13, 2011 | 1998 Volkswagen Beetle
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Need reset code for kenwood kvt-715
i have attached a link with a HOW TO reset a kenwood radio code. i have never tried this on any of the KVT units, but its worth a shot.
http://www.tech-faq.com/reset-kenwood-security-code.shtml
Aug 25, 2009 | Kenwood KVT-715DVD Car DVD Player
I have a 97 gmc sierra w/ 5.7 l engine that won't start
replace fuel filter.check fuel pressure.
Jul 18, 2009 | 1997 GMC Sierra
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
Kenwood VR-6070 Receiver Logo
283 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
