Does the Garmin c330 have technician codes or any special unit profile screens. Im looking to see if I can get any stats on way points (or favorites) or xy coordinates of errors in the maps. Is there any special backdoors to tell a tech about the individual unit in one screen, software versions etc.
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running
the battery will have 1% life left. If you turn c330 back on again, it
will flash screen for 3 seconds then die, even charging it at this
point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the
power home or car into Garmin c330. There is a tab in the front Garmin
gray frame of your screen. You must take like your fingernails and
under the logo "GARMIN" pull the whole gray plastic frame off.
Underneath the plastic frame to the right hand side. There is a "RESET"
button. Make sure power is plugged in while hitting reset. Your battery
should come back to life. Cheers
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
