Question about Sharp VC-A410U VCR
No picture with video playback (there is sound)
I have a SHARP video recorder (VC-MH722).  I have it tuned into my SONY TV but it is connected by a SCART lead.  I have just bought this second hand set up.  When I play a video there is only the sound.  I have tried it on the AV setting and on the channel the video is tuned to and get the same result.
Is there anything I can try or adjust to get a picture?
4 Suggested Answers
SOURCE: reording from tv to a sharp vc-a560
I am not sure how I fixed it but It works now. Thank You :)
Posted on Mar 28, 2008
  • 265 Answers
SOURCE: need a user manual
Hello
Heres a list of all manuals.
http://www.nodevice.com/manual/Sharp/page100.html
Please Rate
Thanks
Posted on Feb 21, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Posted on Jul 05, 2009
How do I adjust the tracking on my SHARP VC-SA33 Video Recorder during playback?
hi,
it used to be channel up/
down, but that might be outdated
jm
Jul 26, 2017 | Sharp Televison & Video
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Does it record video clips with sound? I can record video clips but when i playback it has no sound,if it does have the feature then how would i activate it?
Yes, it does record video with sound but this camera has no inbuilt speaker for playback that sound so transfer video clip in computer and playback it with Windows Media Player to get sound and picture.
Nov 05, 2009 | Sony DSC-S930 Digital Camera
I have a Sharp VC-MA31 vhs recorder and I can not tune the channels of my t.v. into the VCR so I can not tape any channels.
you need to put the antenna cable to the vcr first then connect the vcr to the tv the tv gonna be on the 3 channel, and put on the vcr the channel you wanna record
Jul 07, 2009 | Televison & Video
OLD SHARP VC A55HM 4HEADS VHS HQ
look for a tv monitor button then push it!
Jan 01, 2009 | Sharp VC-A554U VHS VCR
No sound on playback
The S-video cable carries picture only. You need to also hook up RCA audio cables from the camcorder to the TV
Dec 30, 2008 | Video Cameras
Oct 14, 2008 | Sharp VC-A410U VCR
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Sharp VC-A410U VCR Logo
108 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
