Question about Lands Phones
The handset shows the word searching, there is no dial tone, the"antenna' symbol is flashing. It rings when there is an incoming call, but it doesn't function.
  • fpaa Nov 17, 2008
    Your suggestion solved the problem. There is another phone (not cordless) in the house and it had continued to work. I unplugged the cordless, plugged it back in, and it works! Thank you!!!
  • 83 Answers
This is a problem that someone i know had with their phone as well. The fix for it was bringing it to where they bought it and they had to reset a certain code on the phone. then it worked.
hope this helps.
Posted on Nov 17, 2008
  • 19,396 Answers
Unplug power cable and phone cable.
Check if there is signal on the phone line , test a different phone cable.
Handset is not ringing. Checked to make sure ringer and volume is on. What else could be the problem.
I assumed you are talking about your wireless phone.
Are you worried about handset ringing or the incoming call ring?
1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone.
Hope this helps. Best regards.
Sep 01, 2015 | Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
Handsets don't ring?
I assumed you are talking about your wireless phone. Are you worried about handset ringing or the incoming call ring? 1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone. Hope this helps. Best regards.
No and we have two phones and neither of them can hear the incoming call yet they can hear us. Nothing happened to the phones they were working and then they did not.
Not likely defective, just need to be reset. If I understand correctly, no ring with an incoming phone call, but the intercom feature works fine. The ringer on the handsets is either "off" it will say no ringer or the base station is not communicating correctly. Intercom is handset to handset. Phone calls pass through the base station first. Of course, check the base unit: power on, phone line plugged in, antenna attached. Then try the phone line to check for dial tone with a regular, "old" analog telephone. If you are using these with a PBX, you must have an analog line installed.
Jul 05, 2014 | EnGenius DuraFon 1X-HC Long Range...
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
No dial tone phone jack tested ok phone rings incoming call when you pic up nobody. changed battery still no dial tone or conection on incoming call
This is caused by a failed wireless signal transmitter in the base station or a failed wireless receiver in the handset, these phones are not repaired unless they are under warranty, so all you can do is replace it, this is the #1 PROBLEM WITH ALL CORDLESS PHONES.
Mar 22, 2011 | Clarity C410 Cordless Phone
No dial tone - phone rings for incomming call but I can't hear or talk
This can be a problem with your handset.
Have you tried a different phone in that same jack?
Apr 17, 2009 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
