Question about HP Pavilion zd8000 Notebook
Hp pavilion zd8000 inverter problem
Hp pavilion zd8000 inverter is not working
lcd tube not on
how solve this problem
  • 458 Answers
You need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Posted on Nov 17, 2008
My display screen is no longer working. I'm assuming that's the problem since I can hook it up to an external monitor and get a picture. Is that something that can be repaired?
it will be the inverter or the backlight. i am working with laptops every day and HP laptops with this problem are very comon. most of the times it is the inverter or the lcd, sometimes this is just a small pcb that needs to be replaced, but in some caes you will need a new screen. sorry for the bad news. get to your local pc repair shop or the retailer and see how you get on.
Oct 13, 2010 | HP Pavilion zd8000 Notebook
Pinky red tinge horizontal lines near the taskbar in display HP Pavilion dv4
sounds like your power inverter is going bad. replace power inverter and see how that works. Other issue if not solved is probably lcd screen. Inverter's can be found cheaper used if you use the serial number on your old inverter for searching, seeing as how inverters are often used on many different of machines. FYI.
Mar 13, 2010 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000
You may be able to buy a replacement LCD from
www.laptoppartsonline.com
Feb 12, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion ZD8000 display problem
Before you invest any further, try the lcd inverter http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/ I have seen them for real cheap. If you take off your bezel cover underneath the display you'll find the inverter9147480.jpg or if necessary you can get a tech to help install. Usually theres a series of beeps when you get a blank screen. Hp pavilion laptops also get hot on the keyboard after a while from long term use and zd 8000 came out about 4 years ago so the display should be a pretty good looking glossy screen. Those are nice laptops to work with by the way.
Oct 12, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000
a power surge could have caused this problem, as you so rightly assumed. motherboards-cpus et,c. are prone to fail or malfunction. even with static electricity.
it could also be a sign that, the tft ( screen ) has faults or the cfl (tube) or inverter have suffered damage.
Mike @ compurepair.
Jun 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 Manuals
Hi, the manual is available in FixYa itself.
The link is http://www.fixya.com/support/p381158-hp_pavilion_zd8000_pf456av_pc_notebook/manual-3309
One external link is
http://www.onlinefreeebooks.net/?s=Maintenance+and+Service+Guide+HP+Pavilion+zd8000+Notebook+PC.pdf+
May 09, 2008 | HP Pavilion zd8000 Notebook
Zd8000 LCD no display
Sounds like your display went out to me. You may be able to replace it yourself, depending on your skill level/experience with electronic repairs. At any rate you'll need to find a reasonably priced replacement screen. I usually find New and Used ones on ebay and laptops for parts there and other internet classifieds and auction sites. You could also get a replacement through HP, but at an inflated price I'm sure. Since yours went out and it's not a simple repair, I would only consider a new replacement screen and after figuring the cost, resources that your laptop has compared to a new replacement, and time involved, only then would I determine whether it's worth repairing or not?
On the other hand, you could check the ribbon cable that connects the display to your Graphics card on the Board and re seat it to see if that cable has come loose causing your very dim display. My experience would lead me to expect the LCD to have run it's course though.
Happy tinkering and Good luck.
Apr 30, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
909 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
