Question about Imperial IFS40 Deep Fryer
Commercial Deepfryer My fryer is not kicking on when it should when the temperature drops below a certain level. I have to tap the temp control knob to get it to fire back up. Do you have schematics laying out what the switch looks like inside and do you have suggestions on how to repair it versus spending $300 canadian for a new switch. Thanks Gord
  • Anonymous Feb 02, 2009
    pilot will not stay lit without pushing in the bleed knob and if we can get the burners going they will also tend to quit
  • 640 Answers
Goto this site http://www.3wire.com/foodservice/ sign in and look for your model.
Posted on Dec 16, 2007
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
Deep fryer
Please confirm that the model no is IFS40..
Waiting for your reply..
Apr 29, 2008 | Imperial IFS40 Deep Fryer
Fryer is cutting out after certain temp and tripping hi limit. I replaced Hi Limit, Thermopile and Thermostat and it worked great for two days and then kicked out again, tripped Hi Limit. I'm baffled...
Hi there
Hi limit will trip at 450F.
Check your thermostat setting, then check its calibration, this way you will be able to verify where the problem is.
If the setting and calibration of the thermostat is good, check the hi limit sensing bulb, it should not touch the fire tube because if it does, it will sense high temperature and will cause premature tripping.
Regards.
Jul 11, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer wont lite when temp knob is turned up to 350 range pilot is lit
Observe the thermostat when set to higher temp, you should hear a clicking sound as the mechanical contacts inside closes, at this point, burners should fire up.
Thermostat can be tested by checking the continuity across its terminals (using an ohm meter) when set to a temperature higher than the oil temperature.
Also, the thermopile must be free of soot or any form of dirt and the pilot must have good flame quality, gas pressure should meet the nameplate's requirement.
Jun 09, 2011 | Imperial IFS40 Deep Fryer
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
My refrigerator only kicks on when I adjust the temp knob.
You need to replace ( or have it replaced ) , the thermostat . The piece the knob pushes onto . The liquid is seperated inside the thermostat cap tube , causing the internal contact not to close . Also , a tap on the knob , will start the refrig , until it reaches temp , but then may not restart until another tap . Replace it and that will solve the problem .
Apr 20, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
High limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Jul 05, 2009 | Pitco Frialator SG14 Deep Fryer
The thermostat for a GF28 is a Cecilware L099A or F. It is not repairable, but any reputable commercial parts place should have it available for around $90 US.
May 02, 2009 | Cecilware GF-28 Deep Fryer
Temperature flux
may be your regolator not working properly. to check it u can use another applience or change it.
Hamid
Aug 11, 2008 | Imperial IFS40 Deep Fryer
Deep fryer
Make the "tap" is to the thermostat, and not the gas valve. If it is the t-stat, try cycling the knob back and forth, low to high several times. This may free up the contacts in the t-stat. But in general, if tapping "fixes" it, you need a new one.
Good luck - Mike
Imperial IFS40 Deep Fryer Logo
209 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
