Question about HP Office Equipment & Supplies
HP Officejet 13640 All in One Printer- How to use wirelessly from remote laptop.
  • 178 Answers
SOURCE: Can't print wireless from new Vista Laptop to HP 6110 - Help
Windows Vista is a "MEAN" O/S. Not all of the bugs are fixed yet and still hard to find compatable hardware for it. Microsoft did Vista completely different than other O/S's, they released it to program developers to retrofit the printers and such only 1 month before it hit the shelves. With Windows XP and other predecessors, the released them 6 mos before it hit the shelves. I am more than positive Microsoft will get their act together soon, until then, there will be these problems. I have tried EVERYTHING I know to work around it and haven't found a solution. Any other Suggestions from the Techs on here will more than likely be a dead end also. If I am wrong, I stand corrected. Good Luck to you.
Posted on Mar 15, 2008
  • 2692 Answers
SOURCE: HP Wireless Printing Upgrade Kit - HP G55 Officejet Printer?
Yes ; The Officejet 6000 series os one of thse listed on the HP website under the "Wirless upgrade kit" that is compatable.
Posted on Feb 05, 2009
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
  • 316 Answers
SOURCE: How do I print wirless on a HP Officejet H470b
Hello my friend.First you must install the software if you haven't.Insert the Starter CD that was with your printer into the CD drive,the menu runs automatically,if its not double-click the Setup icon on the
Starter CD.On the menu, click the button for the connection method you want to use(wireless).Follow the onscreen instructions to complete the software installation.
After that we are going to create a wireless profile.
Open the configuration utility for your computer’s wireless network card, then do
the following:
Create a new wireless profile with the following values:
• Communication mode: ad hoc
• Network name (SSID): hpsetup
• Security (encryption): disabled
Activate the profile.
Wait two minutes for the device to obtain an IP address, then print a wireless
configuration page.
On the configuration page, verify the following for the device’s network settings:
• The IP address is not
Posted on Feb 08, 2010
  • 5 Answers
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
Posted on Jun 12, 2010
How do I print wirelessly from my Samsung Note 3 to my HP printer?
Go to the Google Market and download an apps called HP All-in-One Remote and install it in your Samsung Note 3.
Then while your Note 3 and HP Officejet were in the same wi-fi network, your Note 3 should be able to detect the HP printer. Then you could select which documents to print and whether B/W or color.
Jul 26, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
I have a HP laptop with Windows 7 and an HP Officejet 7310 printer that was working fine until I installed a new Linksys Wireless Router N, now my printer is not recognized on this laptop but is recognized...
You need to install the printer in the Win7 machine.Or find it wireless, if the printer is on the old you can "share the printer with the Win 7.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
I have a HP Officejet Pro 8500 printer, Model No. A909a. Is it a wireless printer? Can I connect my laptop to the printer with an ethernet cable?
Yes to both your questions!
If your laptop has wireless you need not use the cable if you connect via wireless to the internet router, you can use printer wireless to , you just need to seup the laptop to use the facilty.
You setup the printer through "Tools" look for Network and "Wireles Setup Wizard"
Same applies with the laptop through control panel.
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Apr 10, 2010 | Computers & Internet
Recently bought an HP Officejet 6500. How do I
even though my laptop has been to the hp laserJet 1010 printer, the printer doesn't print !
Oct 31, 2009 | HP Officejet 6500 Wireless All-in-One...
Using HP laptop running Vista wireless intranet connection to HP desktop running xp and desktop hardwired connected to HP Officejet 6110. Can not get laptop to print on network. All internet and other...
The printer needs to be installed by you as "Adiministrator". When installing the printer you need to hold down the "Alt" button when clicking n Add Printer function. It will then give an option of installing as Administrator.
May 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Ben Johnson
