Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
45 degree cut
Hello!
I lost my manual and I need to adjust my 45 degree cut on my Makita. How do I do that?
Thank you.
  • 1 more comment
  • cubswinserie Apr 14, 2009
    There is a positive stop at 45 (and other angles). When I set it at the positive stop for 45, make 8 cuts to form the 4 sides of a frame, I find ou that clearly the 45 stop does not cut a 45 degree angle. Each joint has a gap of significant and very visable amount as it runs from the ooutside to the inside of the joint.
  • Anonymous Mar 13, 2014
    cutting 45 degree angles
  • Anonymous Mar 24, 2014
    i am building a table and i cut my wood at a 45 degree angle and when i aut my other piece that is also cut at a 45 drgee angle next to it the corner doesnt mate up properly there are little gaps how can i fix this
    Problem Solver:
  • 15 Answers
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Posted on Nov 18, 2008
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
I bought the 10" compound
I have been in the same situation in the past, with a mastercraft miter saw to a point of using playing cards to get that nice tight miter joint. placing the cards between the fence and the piece i was trying to miter.Rioby makes mastercraft all thought they are a good saw they have their limits to the precisions of their cuts. good for fences,decks, stuctural framing ect, were a degree two is not a big thing,but when making furniture or interior trim work or picture frames or hobby craft you need to buy a good pro saw like a dewalt or bosh sliding compoud miter saw they may cost more **** their worth the money they are very precise and will last a life time if taken care of .It will be worth the money when you get that perfect cut every time you use it,it will put the JOY and fun back in your projects and not to mention qualaty in your master pieces.
Apr 01, 2011 | Ryobi 10 In Miter Saw With Laser
How to adjust saw to cut a perfect 90 degree and 45 degree cut
I would go to Makitausa.com and download a manual. what you have aproblem with is either a bent fence or just misalignment. simply all you need is a good square, put the head at 0 degree and check to see if out, making sure not to put square on the teeth of the blade, if it is out there are 4 13mm bolts that hold fence in place loosen them and starting from the left side put it at the exact dead nut. snug the bolt and then check the right side. I usually check them 3 times for accuracy when you are confident snug all the bolts and recheck. Let me know if you need more assistance
Jan 19, 2011 | Makita 10" Dual Slide Compound Miter Saw...
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
It doesn't give me a precise 45 degree cut
the fence might be bent or needs to be squared up. how is the 0 degree. If you need to find out how to square this tool go to Makitatool.com and type in your model number and you can download a user manual with the instructions on how to do this, let me know I work on them every day. Good luck
Jan 20, 2010 | Makita 10" Dual Slide Compound Miter Saw...
The cut is not square on 45degree miter
Hello. First of all adjust your saw on straight cuts so that it is spot on 90 degrees. Then go to the 45 and test it again. Being off a tiny amount at 90 degrees is compounded when you go to 45 degrees.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
I cannot get a perfect 45 degree angle with my Makita circular saw. Is it me or the saw??
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Jul 29, 2009 | Makita Saws
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
45 degree cut
loosen the miter lock, tilt the table to 45 deg. tighten the miter lock
Feb 19, 2009 | Makita 7 1/4" Circular Saw 5007NB
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
256 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
