Question about Canon Sure Shot AF-10 Date 35mm Point and Shoot Camera
Canon Sure Shot Af-7 battery cover
My in-laws have asked me if I can repair their Canon AF-7 film camera - the batter cover catch has broken. I have managed to source a replacement cover, but now need to know how to take the old one off and replace it with the new one!
I have undone the five small 'philips' screws around the outside of the camera body but it not opening up!!
Help please!!
5 Suggested Answers
SOURCE: Halo around af points
I have the very same happening to my 400D, I took it back to the shop that I bought it in and they said it was no problem and like you it doesn't do anything to my photos, Willie.
Posted on Oct 27, 2007
daverh
  • 117 Answers
SOURCE: Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Posted on Jan 14, 2008
SOURCE: Canon 400D CF pin broken, power down
where is this board?
thks
Posted on Mar 23, 2008
SOURCE: Replacing a part on my Canon PowerShot A610 Digital Camera
is it the same Powershot A540 as well?
Posted on Nov 11, 2008
cpt100
  • 154 Answers
SOURCE: can't find battery compartment for canon sure shot tele
The battery cover should be on the left side of the body looking at the front of the camera next to the strap holder.
Posted on Mar 27, 2009
What batteries can i use in the samsung af zoom 1050
You will be looking for a 123A battery that you will most likely find at a battery store, or many an electronics store like Best Buy. Or you can google your camera model and order the battery online.
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
How to load film
http://www.usa.canon.com/app/pdf/compact_film/Sure_Shot_Z135_manual.pdf
The link above will take you to a .PDF that is an owners manual for the Canon Sure Shot Z135
On page 14 it lists how to load film into the camera.
1. Slide the back cover downwards
2. Insert the film
- Make sure the film is positioned above the film guide
3. Pull the film tip across until it reaches the film tip marker
- Make sure the film is flat
4. Close the back cover
5. Turn the dial to (auto)
(Turn the power on)
the camera will automatically advance the film to the first frame.
6. "1" should be displayed on the frame counter
If this show zero there has been an issue, make sure you are using the proper film for the camera
Aug 24, 2011 | Canon Sure Shot Z135 35mm Point and Shoot...
I would like to know what type of film, which speed of film I need to use in a Canon AF.7s please.
The film you need is depend also for the particular occasion you gonna use your camera. If you gonna shoot on sports arena where there is a lot of action, you need a high speed film say "ISO 500" film and those type of film depends on the availability of brand of film in your area or country. Try to canvass in your local photo supply in your area. I hope this advice help you.
Mar 17, 2011 | Canon Sure Shot AF-7S 35mm Film Camera
What film do you use for a canon af-7s
The Sure Shot AF-7 is a 35mm camera. That means it uses 35mm film (sometimes known as size 135). You can use black&white film or color film, either slides or negatives (for prints).
You may download a copy of the manual here.
Jan 28, 2011 | Canon Sure Shot AF-7S 35mm Film Camera
I have a Canon Sure Shot Tele dated around 1993. Its a film camera and I'm having trouble finding where to replace the battery.
If it's the TELE/MAX, the battery cover is on the left end of the camera (as viewed from the back). Slide the cover toward the back to open. It takes one CR123A battery, positive terminal up.
If it's the TELE, the battery cover is on the right end of the camera (as viewed from the back). Use a precision screwdriver to unscrew the two screws. Hook your thumb against the side of the battery and lift upward, then pull the battery out. It takes one 2CR5 battery.
Do not replace the battery when film is loaded.
Jan 05, 2011 | Canon Sure Shot 80 Tele/Date 35mm Point...
Can't find battery compartment for canon sure shot tele
Mar 26, 2009 | Canon Sure Shot 80 Tele/Date 35mm Point...
Jan 11, 2008 | Canon Sure Shot 105 Zoom 35mm Point and...
Canon Sure Shot AF-10 Date 35mm Point and Shoot Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
