Question about Lexmark X75 All-In-One InkJet Printer
It wont print
My printer does not print any documents sent from the pc, either on word as a document or anything that i send to print from the net. this error message comes up:
Communication not available - the printer cannot communicate with the computer. try these solutions:
-disconnect and reconnect the USB cable
-disconnect and reconnect the printer's power cable
-restart your computer
all of which have been tried. the thing is that when i scan something it does come up on my computer, the auto feed button works and takes in paper, anything i try to copy directly from the printer does work (for example if i want to make a copy of something in the scanner.)
please could you help
  • 59 Answers
You see what it imply is that it a software problem so what you will do is find the printer driver that come with your printer and install it. if it new you buy it software most come with it but if you have done it befor. it means you have not install the driver properly. i will like if you can uninstall the driver then reinstall is back. those devicese take deferent way of installing their drivers some what you do is befor connecting the cable to you pc install the driver on the pc first while other you will connect the device to your pc then the installation wizerd will promt and ask if you will do the intalation manually or authomatically you will just follow the questionair.
Posted on Nov 17, 2008
I have sharpAR-5620V I have installed the driver it can scan but can't print my documents from my Pc. (Documents sent from my pc to the copier can't print
first let me start by asking, what is the operating system? are you able to see the printer in "devices and printers"? also when you send the job, are you able to see the print queue at the bottom of the right hand side on the task bar? let me know.
Oct 21, 2016 | Office Equipment & Supplies
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Printer does not print computer documents
The queue is so choked with documents the printer gets confused and loses its sense of priority. Shut down the printer and disconnect power to clear its memory. Wait a few minutes and reconnect power. Start sending one document at a time to the printer and you should get results.
Mar 08, 2014 | Samsung Office Equipment & Supplies
While attempting print a document, Dell All-In-One 948 InkJet Printer printed a document that was not opened. How can that happen? I haven't tried anything to fix it because I don't know where to...
Most likely, this document was already in the print queue and never got printed. If that's the case, open notepad, enter the following commands : net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save this to your desktop as DeletePrintJob.cmd, run as administrator (right click on it, select run as administrator), then reboot your pc/powercycle the printer. This should resolve your issue. If not, please let me know.
Mar 05, 2011 | Dell 948 All-In-One InkJet Printer
Hi, I?ve critical problem. I have a printer HP 1020 which is installed with my pc. And we have 10 PC in my local network. We use above printer share basis. But problem is when some one (without my pc) try...
The spool service basically holds what you want to print in memory and print it while you can do other stuff..
Check you spool settings here:
Although you can control whether to use spooling or not, you'll typically want to spool documents you send to printing. Spooling documents expedites the printing process, and allows the application that sent the document to release control back to the user much faster this link will show you the settings you can select but the real settings will take place inside your printer properties.
http://technet.microsoft.com/en-us/library/cc739118(WS.10).aspx
Hp 1020 spooler settings, unable to find the specific one but i believe when you go into the options just follow the steps provided in the link with similar images and try selecting a different spooler option, this can indeed affect what's happening with the printer versus the systems...
http://technet.microsoft.com/en-us/library/cc722526.aspx
Aug 12, 2010 | HP LaserJet 1020 Printer
Yellow light flashes but won't print. Paper tray is full.
If you had sent the document for print, try cancelling it and switch off the printer, unplug the USB cable to the printer and plug it again. Put on the printer and send the document for printing again. Make sure that no other document is pending for printing and send for print again.
Regards
Sep 26, 2009 | HP LaserJet P2015dn Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
