Question about IOGear GCS632U 2-port KVM Switch
Causing fatal error when not plug into KVM Switch
I have my PC and laptop connected to this switch and it works great except when I remove the laptop I get a fatal blue screen error stating something about IRQ_Less_or_Equal and then it dumps physical memory. This happens when I just remove the laptop or if I shut it down remove it and boot. My IT Dept. thought it had to be a problem with my laptop so they replaced it. I came home yesterday and plugged it into the KVM and worked all day. This morning I shutdown and took my laptop into the office. I booted and bingo, the same blue screen error on the new laptop. If I reconnect to the switch and reboot everything works fine. My laptop is basically useless unless it is connected to this switch. Please help.
    Scholar:
  • 143 Answers
Dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
IOGear 2-port KVM Switch
Posted on Jan 02, 2009
  • Chinmay Joshi
    Chinmay Joshi Jan 02, 2009
    dear sir,
    thanks
    plese vote
    jo_chinmay
One pc os blue screen and fatal error
Try to note the exception error and search it on google to pinpoint what is causing it. Also recall the last change you may have made to the PC and undo it. Install a utility or application? Also processor fans go out and when the processor heats up you get blue screen error.
Jan 13, 2018 | Blue Computers & Internet
Tip
10 reasons why PCs crash-You must know tip 2
2 Bad Ram
Ram (random-access memory) problems might bring on the blue screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and will need replacing.
But a fatal error caused by Ram might be caused by a mismatch of chips. For example, mixing 70-nanosecond (70ns) Ram with 60ns Ram will usually force the computer to run all the Ram at the slower speed. This will often crash the machine if the Ram is overworked.
One way around this problem is to enter the BIOS settings and increase the wait state of the Ram. This can make it more stable. Another way to troubleshoot a suspected Ram problem is to rearrange the Ram chips on the motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling Ram try not to touch the gold connections, as they can be easily damaged.
Parity error messages also refer to Ram. Modern Ram chips are either parity (ECC) or non parity (non-ECC). It is best not to mix the two types, as this can be a cause of trouble.
EMM386 error messages refer to memory problems but may not be connected to bad Ram. This may be due to free memory problems often linked to old Dos-based programmes.
on Mar 04, 2010 | Computers & Internet
Explain how bsod infected pc from Microsoft downloads in 2016,years after it was diagnosed
A Blue Screen Of *****, which is the colloquial name for a Fatal Exception Error, is NOT an infection, but a bad interaction between Hardware and Software, usually drivers. The drivers are updated by manufacturers and Microsoft distribute them to help the Windows Operating System.
I haven't seen a BSOD in probably 15 years!
Oct 31, 2016 | Microsoft Computers & Internet
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
Hi Guys, i have been trying to reinstall windows xp profressional on a celeron PC but when i go into the setup mode the screen displays the message as "Do u want to recover data" 'yes or no' and...
Well, seems like your windows totally crash!!
You need to reinstall it with option"No" when recovering data pop up.
You need to install it using the first boot option, insert the Windows CD, and booting using the CD first.
After enter the windows XP setup menu, make sure you format the drive for Windows installations.
Hope it works
Feb 22, 2010 | Compaq Presario C552US Notebook PC
Blue screen Fatal System Error. How do I get the laptop to work?
damaged OS windows or most commom hard drive failer..
Apr 23, 2009 | Dell Inspiron 2200 Notebook
Blue srren fatal error
you was probably installing updates in the background and youve interrupted install and shutdown improperly (reason)
turn on pc and press f 8. if youve never done this before;as soon as you see anything at startup keep pressing f 8 youll still get to the place you want to be.select start up using last known good configuration.
Mar 02, 2008 | HP Pavilion dv6000z Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
221 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
