Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Blank screen on Powershot S40 - I don't think it's E18
I have a Canon Powershot S40. I can turn the camera on, have the lens extend itself out, and see the icons on the LCD screen (like "auto" and flash etc.), but the screen itself is blank - no picture. There is no E18 message on the screen and judging by what I've read online, I think it's another error .. Any ideas?
This is a problem with the CCD card. Canon has issued a recall and will fix/repair for free. Go to the Canon website and search for CCD to get more info (or call them direct).
Posted on Jul 02, 2007
SOURCE:
E18 screen msg
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
When i turn my camera on, its a blank screen with
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E18 Error message on my Cannon PowerShot A410
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 14, 2009 | Canon PowerShot A410 Digital Camera
Camera does not go on
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E18 on Canon Powershot A95
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
Blank screen - I don't think it's E18
Try and clean the LCD connector _flexible connectors. If you are able to see the dark picture- The back light panel is defective or improper contact. If the picture is perfect in the PC when you download,,then the LCD may be defective For LCD pl.e mail me...may be we can give a new one.
Dec 02, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
