Question about Sharp Notevision XG-C50X Multimedia Projector
Sudden drop in brightness
I have a Sharp XG-C50X, about a week ago it dropped to being about half as bright as it used to be. I checked the lamp life which is now about 50%, I cleaned the air filter, I cleaned the lens, I checked the bulb and menu settings, and could get no brightness back. This projector is now about 5 yrs old, and the bulb is almost one year old. I am wondering what might be wrong? Is it worth fixing?
5 Suggested Answers
mastertech48
  • 149 Answers
SOURCE: sharp xg-e850u projector owners manual
I've searched all over...heh, I've got TONS of Sharp service manuals but *not* yours...I did find, however, the xg-e650 manuals on manualsparadise.com. Sharp units, a lot of times, are very similar in architecture, functions, parts, etc. For example, practically any Sharp remote will work on your projector...BTW, the lamp you need is a BQC-XGE850U/1 and sells for $292-389 dollars.http://reviews.cnet.com/peripheral-accessories/sharp-projector-lamp/4505-8309_7-31382143.html?tag=mncol;lst
Posted on Sep 09, 2009
  • 4234 Answers
SOURCE: I'm looking for the service manual for a Sharp XG-C50X
To my knowledge this manual is available on paper only. What is the problem you are trying to solve? Perhaps we can help you to solve it.
Dan
Posted on Jan 04, 2010
Testimonial: "good info"
arthurroger
  • 170 Answers
SOURCE: auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Posted on Apr 23, 2010
  • 567 Answers
SOURCE: SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Posted on Jul 31, 2010
    Brightness Flickering
    1,the mother board is good
    2,the lamp ballast is good
    3,the lamp is defective, replace it with a new bulb ,
    you need a new Original lamp (USD290)
    Have a good day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry Lampdeng Limited
    Mobile: 0086-13178867858
    Wechat ID: 008613178867858
    Whatapp ID: 008613178867858
    Skype: lampdeng@hotmail.com
    http://www.lampdeng.com
    Feb 24, 2014 | Sharp Office Equipment & Supplies
    TV is warming up slowly
    Based on model number indicated and fact it is not shutting down it most likely is the lamp reaching the end of its 2000 hour life.
    Original lamps from Mitsubishi last longer than "generic" ones that often have half the life and are not as bright.
    Jun 11, 2012 | Mitsubishi WD-60735 Projection Television
    My projector doesnt power on and the fan can not be heard .. but the red power light comes on when I plug it up. I changed the lamp and lense and cleanned the filter. Still no picture come on.. iI dont...
    Count how many times the red lamp blink and then check in this manual - which problem refers to this mode of blinking lamp:: http://www.retrevo.com/support/Sharp-XG-C50X-Projectors-manual/id/1075bh051/t/2/
    If you can't find out yourself, consult the Sharp Customer Suppert: http://www.sharpusa.com/CustomerSupport/ContactUs/ContactUsProductSupport.aspx
    If the nothing can help you to find the cause of the problem, bring the projector to the nearest service center to get it fixed (or even better - replaced): http://www.sharpusa.com/CustomerSupport/ServiceLocator.aspx
    Mar 05, 2011 | Sharp Notevision XG-C50X Multimedia...
    The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
    suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
    Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
    SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    Dan
    Jan 04, 2010 | Sharp Notevision XG-C50X Multimedia...
    Sharp XG-C50X Notevision. Doesn't get past "warming up"
    it seems that the powersupply is failed
    Have a nice day!
    Jerry
    Lampdeng Limited
    Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
    Sharp XG-C50X
    Did you reset the lamp hours?
    Aug 21, 2008 | Sharp Notevision XG-C50X Multimedia...
    Sharp Notevision XG-C50X Multimedia Projector Logo
    53 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
