Question about Kenmore 22422 Top Load Washer
Won't spin or drain
This is a Sears Kenmore 80 Series Heavy Duty Super Capacity Model 110.26892690 that we bought slightly used 5 yrs. ago. Machine fills with water but will not move to rinse cycle, won't spin or drain.
  • 2 more comments
  • washer issue Nov 18, 2008
    Washer fills & agitates but won't spin or drain it clicks through the cycles but doesn't do any thing else.
  • Anonymous Nov 20, 2008
    After I had adjusted the water level to small load, the washing machine refused to spin or drain. It only works for water level now, but it still refuse to spin or drain.
  • Anonymous Feb 14, 2009
    Kenmore 80 series washer won't drain or spin. Machine had an overload of heavy pillows and now won't spin or drain.
  • Anonymous Mar 12, 2014
    need a wiring schematic for a sears craftsman heavy Duty 40 Amp Charger/225 Amp Engine starter Model 934 718460
  • 367 Answers
Check to make sure your lid switch is working.
Posted on Nov 17, 2008
2 Suggested Answers
  • 6277 Answers
SOURCE: I have a Kenmore 80 series, Model 110 26862501;
I would think that sort of information would be on the manufacturer's plate, probably at the back, and/or in the manual.
If you have no manual you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 07, 2011
What size is the kenmore model number 11064852400
Maybe Sears can provide dimensional data.
Dec 01, 2013 | Dryers
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22422 Top Load Washer Logo
734 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
