Question about Indesit 24 in. D61 Free-standing Dishwasher
Door catch plate Indesit d61
I have ordered a new Merloni door catch plate as the original has snapped and wondered if someone could tell me how to replace it please. The cost of fitting a £4.00 door catch plate is ridiculous! Hoping some one out there will be able to help me and explain in detail. Many thanks. Callie
  • 3 Answers
Undo the screws at the top of the front door and puul the control unit out this gives you acsess to the door catch which is quite simple to replace be careful the stainless steel is quite sharpe
Posted on Jan 28, 2007
IT IS NOT INDESIT 123. IT IS INDESIT 133
its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
Nov 06, 2011 | Indesit W 123 Front Load Washer
How to wire indesit dg 6100 door control panel, which wires go where?
You will have to contact the manufacturer and ask them for a wiring schematic of that particular model.
Feb 12, 2010 | Indesit 24 in. D61 Free-standing...
Snapped door lock on hotpoint washer/dryer
this happens when unit goes off balance and tub bangs door..open door.. you will see to screws holding the door locking device remove,,now take a screw driver and remove the front wire spring clip..replace latch and door probe,,reverse to put back together
Dec 23, 2008 | Indesit W 123 Front Load Washer
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Indesit D61 Error Code 2... what does it mean?
have no access to manual. but you could...
try to recycle the power. shut off breaker or unplug for a minute or two. then turn back on. it may reset.
good luck
mark
Dec 27, 2007 | Indesit 24 in. D61 Free-standing...
Panel below the door
i would contact the mfg, and order direct. if they have someone near, they will tell you.
should be able to do this on line.
good luck
mark
you can consider making the plumber find the part.
Nov 08, 2007 | Indesit 24 in. D61 Free-standing...
Indesit d61 dishwasher
contact parts dept for unit. check on line. should be easy to get.
good luck
mark
Oct 28, 2007 | Indesit 24 in. D61 Free-standing...
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Indesit 24 in. D61 Free-standing Dishwasher Logo
303 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
