Contributor
- Posted on Jan 23, 2009
Re: Got a new part. don't know how to install it
I assume you either have recieved the separation pad or the paperpick roller. Here are instructions on how to replace both.
Use the power switch to turn the product off and then unplug the power cord.
Figure 1: Unplugging the power cord
Open the print-cartridge door, and remove the print cartridge.
CAUTION:
To prevent damage, do not expose the print cartridge to light. Cover the print cartridge or place it in a black plastic bag, if necessary. Also, do not touch the black-sponge transfer roller inside the product. Touching the transfer roller can damage the product.
Locate the pickup roller.
Figure 2: Removing the print cartridge, and locating rollerGot a new part. don't know how to install it - c00062341.gifploads/images/c00062341.gif" alt="c00062341.gif" class="h_mi" />
Gently release the small, white tabs on each side of the pickup roller by pushing them away from the roller, and then rotate the pickup roller toward the front.
CAUTION:
Use gentle pressure to release the small white tabs to avoid breaGot a new part. don't know how to install it - c00062342.gifb>Figure 3: Releasing the tabs
- Figure 4: Removing pickup roller
Perform one of the two following options:
Cleaning the pickup roller:
Dampen a lint-free cloth with isopropyl alcohol, and scrub the roller.Got a new part. don't know how to install it - c00062344.gifh_mi">
Using a dry lint free cloth, wipe the pickup roller to remove loosened dirt.
Figure 5: Wiping the pickup roller
Removing the new pickup roller from its packaging.
Position the cleaned or replacement pickup roller in the slots on the pickup rolGot a new part. don't know how to install it - c00062345.gif
NOTE:
Circular and rectangular pegs on each side prevent incorrectly positioning the pickup roller.
Figure 6: Positioning pickup roller
Rotate the top of theGot a new part. don't know how to install it - c00062346.gifr into position until the white tabs on each side of the roller snap into place.
NOTE:
Figure 7: Reinstalling the pickup roller
Reinstall the print cartridge and close the print-cartridge door.
Plug the product in, and then use the power switGot a new part. don't know how to install it - c00062407.gif the product.
Figure 8: Plugging the power cord in
Use the power swGot a new part. don't know how to install it - c00062408.gifthe product off and unplug the power cord.
Figure 1: Turning off power and remove power cord
At the back of the product, unscrew the two screws that fasten the separation pad and frame to the product.
Figure 2: Unscrewing the separation pad
Remove the separation pad and frame.
Figure 3: Removing the separation pad
Perform one of the followinGot a new part. don't know how to install it - c00062410.gif:
To clean the separation pad: Dampen a lint-free cloth with isopropyl alcohol, and scrub the separation pad.
- To replace the separation pad: Remove the new separation pad from its packaging
Insert either the cleaned or replacement separation pad and frame and fasten it to the product with the two screws.
Figure 4: Fastening the separation pad
Plug the product in, and then use the power switch to turn on the product.
Figure 5: Turning the product on
