Question about Motorola Mobility RAZR V3i Cellular Phone
Phone display u/s (motorola razr)
I am trying to access using pc as phone numbers and photos still "in" phone but not saved to sim or backed up............Help?!
    Brigadier General:
  • 7,752 Answers
Install the Mobile Phone Tools software you can find this at modmymoto
Posted on Dec 28, 2008
Testimonial: "Used ages ago.....forgot. Thanks. Worked a treat!"
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How do I save my photos to sim card?
No, your sim card provides information like contacts and your number only.
Any phones have memory cards that are for saving Pictures, Videos and MP3s on. This will be better for you as it is removable and can be used on PC's, card readers, printers etc.
Aug 24, 2009 | Motorola Mobility RAZR V3i Cellular Phone
The phone works but the screen is black. Is there a way to retrieve phone numbers saved to the phone and not the SIM card?
hi their wil be a bus connecting the display & the circiut mother board kindly check whether its working properly !!!!!because it is the main component that is responsible for the proper functioning of the display !!!! this is a common problem in fold type motorola mobiles
Jul 30, 2009 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Can't take, send, or receive photos...says "busy try again later"
Try formating the phone, it should be under the phone settings. It will delete everything on the phone so be sure to save your numbers onto the sim card. once its been formatted it should start up as if its the first time the phones been used.
Jun 12, 2009 | Motorola Mobility RAZR V3m Cellular Phone
How do I change number from being saved from SIM to phone?
when you add the number and then select save,changed the option to phone memory instead of sim card
Nov 10, 2008 | Motorola Mobility RAZR V3
Caller id
try and master reset your phone back to the default.....
menu/settings/initial setup/master reset
Jan 10, 2008 | Motorola Mobility RAZR V3
SIM CARD
install motorola phone tool software and plug in connectivity medium after that u can save ur photos....
Oct 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Razr Screen all white.
what you can do is buy a connector kit from a mototola place and connect it with your computer, then you will be able to see all the numbers on your phone, you will have to maybe manualy transfer the numbers but at least you will have the numbers
Jan 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
