My l1720p moniter wont turn on
Is there a fuse or a reset button? L1720P
  • 5 more comments
  • carolrogene Nov 22, 2008
    my old Gateway EV700 monitor shuts off and screen goes blank black, after a while it still comes back, all connections are secure, does it have a fuse or is it going bad or what? thanks
  • jtfromcb Nov 29, 2008
    Turned it off before I left to go out of town for two days. Now it won't turn back on???? LG Flatron L196WTQ-BF
  • mrsjolie Dec 13, 2008
    I turned off my monitor a couple of weeks ago, now it won't turn on. Just a black screen. The power button is blue, indicating that its on.
    What can it be, a fuse?
  • Anonymous Dec 22, 2008
    I am having similar problems with my FPD1975W Gateway Monitors... I switched out my monitor so I narrowed it down to the monitors, and know it's these monitors. I use a double screen and purchased two of these at the same time... They both started to act up at the same time... Now only one will show powered up (blue light) and that keeps turning on and off... I think these are just cheap monitors but still...I expected them to last longer than 2 years, as I am currently using and OLD "Daytek" 15' relick... A bit pissed about that...
    I purchased 2 of these moitors at the same time as I use a double screen for music production and both started having problems booting up... Now only one tries to boot up but keeps stutting itself down... screen ficks once and turns off... Black screen otherwise.. Other screen just shows a pale Blue light that flickers on then offf. This has almost completely stopped and now barely even tries to turn on. I tried an old 15" Daytec monitor I have as a spare and it works great. So I know it's not the video card... The monitors were fairly cheap when I brought them but to be honest I expected more time out of them. Any suggestions? Thanks Cj
  • Anonymous Dec 23, 2008
    The colors of my monitor are like gone.. just blue and such..
  • Anonymous Dec 24, 2008
    i have lg 1932 and the monitor flickers blue and then nothing. I bought a new ac adapter thinking that might solve it but nothing.
2 Suggested Answers
bmwrider
  • 215 Answers
SOURCE: digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Posted on Jun 03, 2006
Message on screen says
the cable is not connected properly or the graphics card has died. please check the connections.
Feb 20, 2012 | LG L1720P 17" LCD Monitor
My monitor was turned off because of a storm. Now it will not turn on. The power button does not show any lights.
AC outlet is good? Otherwise the main AC fuse in the power supply board may have blown, caps are bad, you need to take it apart.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jun 30, 2011 | LG L1720P 17" LCD Monitor
How do you open the case?
Here are the service manuals, one of them should match your chassis:
http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=l1720&kategoria=monitor&kat2=all
I use thin flat blade to crack open starting at the bottom edge and work your way around, it uses plastic finger hooks so you may break some of them, they go in easy but hard to come out.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Mar 08, 2011 | LG L1720P 17" LCD Monitor
There was a power outlage and when the power came back on the monitor would not turn on
Hello, If there is a power outage and the monitor fails to come up, i would want you to take the monitor to a good power supply source and plug it there to see if it will come up, the problem might be with the power source, if not then the problem is with the monitor.if it is dim, i mean the screen then you can be sure is the inverter switch on the monitor,but if i have a monitor problem, the best thing, i would likely do is to get a new one. Regards
Nov 25, 2010 | LG L1720P 17" LCD Monitor
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
Hooked up a used 17" LG Flatron L1720P flat Panel. When I turn it on it says Power Saving Analog Mode and goes black, no instructions with it.
Make sure your power cables are connected properly. Sounds like it's not getting any video data from the graphics card.
If it is not your graphics card, It could be a dead monitor.
Feb 09, 2008 | Computers & Internet
LG Flatron L1720P Loses Display
The backlight inverter board is defective or a high voltage cable going from the inverter output to the lamps is damaged or touching ground.
Feb 07, 2008 | Computers & Internet
Digital power saving mode
Jun 03, 2006 | LG 1720B 17" LCD Monitor
Computers & Internet Logo
567 people viewed this question
Alun Cox
David Payne
David Payne
