Question about Apple Cinema 20" LCD Monitor
Monitor spaz-mcgee ok this problem occurred once before a couple days ago but not to this extreme. it started out with the "." key on the keyboard. for some reason any text input area on the computer started to be filled in by the "." key. it would just repeat itself without stopping. if i hit the "backspace" key it would stop but if i let go, it would continue on its merry way again. it suddenly stopped and now today it happened again. only this time the monitor has gone negative. and by negative i mean like that of the negative of a photograph. i was trying to stop the "." from repeating and pressed as many keys as i could at the same time (i know, not the smartest move ever) but it got the "." to stop. then a second later the screen flickered and then was showing everything like a negative. is there something wrong with my computer or monitor or the connections between? is anyone familiar with this sort of issue? please help!
  • 624 Answers
This is really sounds like a keyboard issue. From your description it sounds like your ?.? key is locked in the active position, note that the key doesn?t have to be down for the contact below to be engaged. This isn?t uncommon, especially with older/cheaper keyboards. A quick test is just to replace it with another USB keyboard, even a Windows keyboard will do for a test. If that solves your problem you can try taking it apart to clean, however, if it?s in warranty I would just call Apple support. If its fairly old I would just bite the bullet and spend $35 for a new one.
Posted on Dec 04, 2006
Philips 190B monitor turn black, then show blue Philips and then it is ok. It kept going through this routine
I could be completely 'out to lunch.' but - what are you doing with the Phillips? Is it connected to Dish? We have Dish. An antique system. I called them a couple of days ago, because I was taping something, and the screen went to a violent pink. The next day, they came out, and replaced Everything. Dish, box, and remotes. They understood that the old sytem was breaking down. Hope you find a solution. These toys - we depend on. Then they implode. Annoying, in the extreme.
Feb 04, 2017 | Philips Computers & Internet
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
Was fine 2 days ago but now wont connect to wireless broadband. Broadband fine. Can't open connectivity menu. No error messages. I dont have a start button??
try system restore. since you dont have a start button, try the shortcut key on the keyboard Simply press the Windows Key + R to open Run from the keyboard. then type: %SYSTEMROOT%\System32\restore\rstrui.exe then press ok
Jun 11, 2010 | Acer Aspire One PC Notebook
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
Car won't run after rain or after it sits for a couple days
you need a tune up new plugs wires and cap an rotor
Nov 07, 2008 | 1990 Geo Prizm
Spacebar stuck
Ok ya gonna haveta get a New Keyboard for ya Lappy... they are relatively easy to replace they are an "All-in-one" thing and usually have a ribbon cable that plugs into the motherboard... ya could disconnect it for now and plug in an external keyboard to ya Lappy to get ya going... But be gentle getting the old keyboard out.. maybe even go online and get a Manual to see how it comes apart.. else it's off to the shop. GL
Jul 29, 2008 | Compaq Presario Notebook
Half Dead Monitor
Dear
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
May 18, 2007 | Neovo F-417 17" LCD Monitor
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all Apple Cinema 20" LCD Monitor Questions
Apple Cinema 20" LCD Monitor Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
