Question about Honeywell Programmable Thermostat Heater
Just moved into a new house and no manual for thermostat
Cant set the timer as dont know how to! its a honeywell cm 51
  • Anonymous Mar 20, 2014
    My CM51 is broken what is an equivalent replacement
    Problem Solver:
  • 17 Answers
Do a search on honeywell.com fror the manual, also there is usually a short version of the instructions inside the front cover.
Posted on Nov 18, 2008
Thermostat Replacement
If you look the model/part number of that thermostat you're looking for on the internet, you should be able to find a PDF file of the owners manual to look at the wire diagrams and it will also let you know if the thermostat is compatible with your current set up with the oil heating and central a/c w/3 zones. RC & RH should be explained in the thermostat manual if the new thermostat wiring has been reconfigured to accommodate your setup. Hope this helps.
Mar 05, 2014 | Honeywell RTH8580WF1007 7Day Touch...
I have under floor heating cannot set thermostat timer
Model number usually located on back of thermostat
Change battery.
Search for model number on web and include .pdf in search parameter.
For example aube thermostat manuals appear following link:
http://www.aubetech.com/manuals/index.php?noLangue=2&noFamille=1
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 28, 2012 | Honeywell Aube by TI0323WU 7Day...
Directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 17, 2011 | Honeywell Heat/Cool Thermostat
Removed honeywell thermostat from new home to install a new honeywell programmable thermostat. Couldnt get the new one to work so reinstalled the old one and it wont work. Checked breaker already, cant...
Do you have a model number for the new and old thermostat? Do you have a split system? This means you have a heater in the house and a condensing unit somewhere outside of the house. Let me know if you have a packaged unit or a split system and we can go from there. I might just be a blown fuse on you board, but I need to know what you have so we can start to trace things out.
May 11, 2010 | Honeywell Programmable Thermostat Heater
How to set the timer
If you would like to download a new Owners Manual...go here and on the right side of the screen are the search boxs...the middle one is the one you want. Just plug in the model...
Click ---> http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Default.htm
If you need more help than this please let me know.
thanks,
RSMITH972278
Oct 13, 2009 | Honeywell Programmable Thermostat Heater
I cant figure out how to set up timer
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Hank
Oct 13, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
Honeywell cm31 no instructions
If you email technical.support@honeywell.com they will be able to email back a user guide for you.
Oct 20, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
702 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
