Question about Onkyo HT-S570S Silver Home Theater System REFURBISHED System
LED power indicator is off
My brother's little boy dropped a quarter into the sub-woofer ( SKW-320X ) and it has fallen on the circuit board. I removed the quarter from the circuit board but then the soubwoofer stopped working. LED is always off. I opened it and checked the power and there is no power from transformer to the circuit. Is there a fuse or something ? Any help is appreciated on what could go wrong ? Can I replace the transformer myself ?
SOURCE: Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Posted on Nov 19, 2007
  • 154 Answers
SOURCE: Onkyo sub woofer
You will only blow fuses and resistors if there is a short of some kind you can change fuses, resistors and capacitors all you like if you don't find the short they will just keep on blowing. It maybe something as small as a bit of conductive material or fluff or dust on chip board wipe board down make sure it is clean (a clean toothbrush is perfect) and there are no signs of burns on either side of the chipboard befor you change anything. If there are burns or greenish build up clean them with some metho or water on a cloth not to damp though and make sure Burn or corrossion hasn't taken off the protective layer on the board.
Then try new fuses. Hope this helps you
Posted on Jul 25, 2008
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
  • 308 Answers
SOURCE: My onkyo skw 200 sub woofer is blowing fuses as
The amp output stage or the power supply is shorted. Service shop type repair.
Posted on Mar 04, 2010
SOURCE: sub woofer doesn't work.
Turn the amplifier on.Go to audio menu select sub-woofer mode to on position.It should solve the problem
Posted on Jan 24, 2011
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
Which circuit is used in sub woofer
the circuit for sub woofer consists of a transistor in parellel to the capacitor to supply power and moreover other I.C's or transistors depending upon the size of the sub-woofer achintya1915.jpg
Dec 06, 2010 | Office Equipment & Supplies
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
Sub woofer hum sub333
Hum is caused by shielded audio cable positioned too close to mains transformer. Open rear side panels and locate twin grey shielded cables from second amplifier board going to little printed circuit board screwed to the back of the plastic box that covers all I/O connectors. Just reroute this cable so it has more distance to the transformer and the hum will be gone!
Aug 21, 2008 | Audio Players & Recorders
Sub-Woofer
you must replace the board with new one.
Jun 01, 2008 | Panasonic SC-HT930 System
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
Onkyo HT-S570S Silver Home Theater System REFURBISHED System Logo
43 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
