Question about HP DeskJet 970cse InkJet Printer
970Cxi - spring-loaded clip holding the black cartridge broke
Part number T-360733. HELP! Is it possible that a replacement part might just be available for me to get this machine going again?
jonniewalker
  • 1031 Answers
SOURCE: 970cxi hp printer
the PCA is held to the carriage /cradle by usually one or more screws. sometimes these loosen over time, so while the contacts on the PCA and the ink cartridge look ok, they're not actually making good contact. try removing the pca from the cradle, and reattaching it, making sure you torque the screws down firmly (but don't crack the board). sometimes a small washer or shim helps to get the board closer to the carts.
many times if you look along the top of the cradle/PCA assembly, you will notice that the gap between the board and the cradle is not uniform. this is usually a dead giveaway, and snugging up the screws will usually fix it.
also if you closely examine the cartridges, you may notice that the indentations or scratches on the contacts aren't uniform which may also point to a skewed PCA.
Posted on May 17, 2008
Joed911
  • 4338 Answers
SOURCE: Broken clip for black ink cartridge
Unfortunately, this is not an easy fix. To replace the ink cartridge holder, you would have to dissasemble the whole Print head/Carriage assembly. The when you put it back together , there are timing factors to be set. With printers so inexpensive, I would opt for a new unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2008
Bappa170873
  • 505 Answers
SOURCE: Can I replace the PSC2210 print cartridge hold down lever?
The entire unit which holds the cartridge needs to be replaced. get it dont by some local tech shop.
Thanks
Posted on Nov 26, 2008
  • 137 Answers
SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Mar 02, 2009
sfks
  • 14 Answers
SOURCE: CARTRIDGE JAM
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
341
Posted on Mar 19, 2009
The printer is only printing in Black and the color cartridges are full.
hello slimavocado,
. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Thanks.
Sep 06, 2011 | HP DeskJet 970cxi InkJet Printer
I have installed a compatible cartridge and the printer is not reading, I have used compats before and they have worked fine?
A blinking orange light means an empty or incorectly installed printer cartridge. Be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color looks the same but will generate an error. Also, ensure that the cartridge is not empty or dried out.
Sep 29, 2009 | HP DeskJet 970cxi InkJet Printer
Hpdeskjet 970cxi only prints blue and black
When refilling cartridges it doesn't always work. replace the ink for known good or new cartridges.
Feb 19, 2009 | HP DeskJet 970cse InkJet Printer
Regards,
Dec 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Thanks
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
Blinking lite on a hp deskjet 970cxi printer
2 reasons.
1)paper jam internally. chk carefully.
2)paper sensor problem.
just moove a paper in tray &tell me green lite is glow/not?
Aug 11, 2008 | HP Office Equipment & Supplies
7310 office jet all in one - black ink problem
You are right about the "extended paper clip".
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place. I hope I can find the part and remove and replace it easily. That I haven't done yet.
Mar 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP DeskJet 970cse InkJet Printer Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
