Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
Temp to cold
I have a new( 5 days old) lg side by side model lsc27910tt. set to the warmest temp it is 20 degrees in the refridgerator compartment at the back, warmer to the front. fans are runnimg. temp controls make no difference. service tecs are unfamiler with the unit and so far unable to fix it.
  • 700 Answers
Do you hae all the shelves an ddrawers installed correctly and have you loaded up the refrigeerator yet because this unit useds a temperautre sensing to determine the tempoerature that it is and it does not work very wellif the refrigeratoipor is allmost empty. That actually goe for all units hat the freezer/refrigerator operate more efficiently if its partially full like 60%. LEt me know if this helps and if not don't rate until your poproblem is resolved and then rate the best solution Please. Thanks for using FixYa.
Posted on Jan 01, 2009
Freezer and refrigerator are not keeping cold
the thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Wide variation in temperature in refrigerator section (40 degrees in top, 20 degrees in bottom, also, freezer set at WARMEST setting is ten degrees below zero.
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
Aug 17, 2011 | Amana Refrigerators
The refridgerator side is too cold- i have it set to the warmest setting and everything is still freezing in the fridge. Any help would be great thanks.
try to adjust on a warmest setting then observe unit if not replace your thermostat means the sensor is deffective iinstall new thermostat.
Feb 05, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezing items in refridgerator
make sure the air passages are not blocked with food produts the other fix might be to un plug refrig and let it defrost for a day make sure you leave doors open
Dec 31, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
WHAT SETTINGS SHOULD MY LG REFRIGERATOR BE SET ON FOR VACATION MODEL NUMBER LFC22760
SINCE MOST CONTROLS WILL ONLY CHANGE THE TEMPS ABOUT 5 DEGREES +/-, IT DOESN'T PAY TO CHANGE THE CONTROLS AT ALL. IF YOU WANT TO, SET THE CONTROL THAT TURNS OFF THE UNIT TO THE WARMEST SETTING BEFORE OFF. BE SURE IT IS RESET TO 38 DEGREES WHEN YOU GET BACK.
Apr 16, 2008 | Refrigerators
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
80 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
